i have two dvd 5's that i split using dvd fab that i want to convert into a dvd9 again. is this possible? if so how?
You could rip the VOBS to your hard drive, then use TMPGENC DVD Author to combine them into a single track. You'll need version 1.6 to do it tho.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
a. YESOriginally Posted by guns1inger
b. YES
c. NO
so can it be done with any program but TMPGENC DVD Author? from my expirence, tmpgenc slows down my cpu therefore i rather not use it. -
I'm thinking DVDRemake Pro might be able to help you here.
If in doubt, Google it. -
jimmalenko, will this program rebuild the dvd smoothly or leave the transition screen on it?
how to convert dvd with dts audio to a dvd playable on a dvd player
By flannob in forum Newbie / General discussionsReplies: 5Last Post: 19th Sep 2010, 07:46 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 02:35 -
trying to convert old vhs tapes to dvd, used sony direct to dvd, not good
By hygieneboy in forum Capturing and VCRReplies: 27Last Post: 4th May 2009, 14:57 -
Convert PAL 16x9 DVD to NTSC DVD w/ Procoder - Less Image-More Borders Why?
By tubularusa in forum DVD RippingReplies: 15Last Post: 5th Aug 2007, 02:26 -
How do I convert double sided dvd to dual layer dvd?
By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 05:04
