How the hell do you add the quicktime effect filters to your video? I've tried but all I get is the effect and no video. What I did was drag my clip onto the timelime and then add the filter and selected the fire effect but when I encode it the video isn't there just the fire is there, can anyone help!
Cheers.
HI,
OK put your avi in video line 2. Then put a black video in video 1B. ( File - new - black video) Make the black video as long as your avi ( Rightmouse click- duration...).
Select the avi. video- rightmouse click- video options- transparacy ! Now your in the transparancy settings!!
KEY TYPE choose screen .
Under the SAMPLE Directory screen you see 3 icons : choose the first : half white /black. Press ok ......
To see your effects on your sreen: go to project-..project settings.. keyframe and rendering.... select preview ..to screen !!! Your avi....wiil burn!!! Marhart71
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43 -
Adobe Premiere Elements
By willmington in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2011, 04:14 -
Adobe Premiere Pro 2 Help
By slicebogey in forum EditingReplies: 6Last Post: 9th May 2011, 18:21 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 04:17 -
Adobe Premiere Capabilities
By jwfc in forum Newbie / General discussionsReplies: 2Last Post: 22nd Oct 2007, 17:18
