Has anyone tried the Lumenlabs projector kit? I want to know of someone's experiences before starting to buy $400 worth of parts.
Thanks!
LS
Results 1 to 10 of 10
looks like crap -- it is crap .. will always be crap and will stay crap ..
This isn't the project where you put a tv in front of a lens. It is a lcd projected with a 400W or higher projection system. Results are awesome, but not enough details up front before spending the $$$.Originally Posted by BJ_M
LS -
This should be a sticky with the IPod threadOriginally Posted by BJ_M
Originally Posted by LSchafroth
i know exactly what it is ---- it is still the same crap ...
I could go on and on about lcd panels and heat and uv stabilization and beam spread and hot spotting and warping and lens aberations and focus points and planer surface and color temps and lack of and contrast and and and and .........
but waste your money and go for it ....
you know you can buy a really decent dlp projector in the $1000 range for home use ...
Have you seen these results 1st hand?
In the old days I ran a portable computer with a
12 inch lcd panel designed to sit on
top of those old overhead projectors.
It had a res of 800x600.
While ok for basic text and slides, the
picture quality was marred by the cross-hatching
you get with magnified lcd screens. The lines
are so fine they almost disappear when photographed
with say ISO 400 print film, but to the human eye
they are a huge distraction.
Also consider that you will be watching the picture
for 80 minutes or more. What looks great at first
glance can turn into a real headache down the track.
$1500 bucks can buy you $10,000 worth of 2 year
old projector technology. Some rainbows and minor
artifacts but very viewable. -
I've seen three of them first hand now. They spent around $300. The picture is awesome. Most of the issues you mentioned are taken care of or not enough of an isue to be visable. What do you expect for $300 though.Originally Posted by BJ_M
Better then spending $1000.
LS -
I personally am not a big fan of cardboard boxes or plywood boxes sitting in my living room. I also have a real issue with the TV being in the back of the room instead of the front. That's right up there with leaving only a little milk left over in the carton in the refridgerator.
Hello,
You could paint them gray or cover them in duct tape to make them look shinyOriginally Posted by smearbrick1
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
diy telecine - monitoring issues
By TopazUK in forum Capturing and VCRReplies: 0Last Post: 2nd Mar 2012, 15:56 -
Would a diy anamorphic lens work on a 4:3 projector?
By yoda313 in forum Newbie / General discussionsReplies: 10Last Post: 17th Jan 2011, 15:49 -
DIY speakers?
By Haopengyou in forum Off topicReplies: 3Last Post: 21st Jun 2010, 00:33 -
Some DIY Camera Stabilization Ideas
By Soopafresh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th Dec 2007, 01:32 -
Low budget DIY
By guns1inger in forum Off topicReplies: 2Last Post: 17th Sep 2007, 03:31
