I wish to backup my videos onto dvd. I have a standalone dvd recorder connected up to my video. Can I just do it this way
To be brief: Yes and No
Most of your home made tapes will probably transfer without any problem.
Some of your tapes, however, may have technical issues that will need to be dealt with during the transfer. The fanatics (me included) use a Time Base Corrector to "clean up" certain portions of the video signal. Some people use a Proc Amp to adjust the Contrast, Brightness, Color, & Hue. But these devices can't always solve all issues. Furthermore, they can be costly to purchase.
In the end, it all depends upon the size of your wallet & your commitment to getting your project done.
I'm sure there will be other comments. So read everything carefully.
Good Luck! -
so basically if I just press play on my video and record on my dvd it might work
If everything is connected correctly, yes.
If it doesn't work, the machines might not be connected correctly. Make sure you have good cables, and the outputs from the VCR are connected to the inputs of the DVR. Next, make sure you have selected the correct input on your DVR. Then press play on the VCR & record on the DVR. In most cases this will be all you need to do. If it doesn't work, there is either a technical issue with the tape or with the equipment.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 02:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
