I have read the posts, and I apologize if this has been addressed before, but, again - newbie here...
I'm about to buy a DVD burner, and would like to make stuff for home consumption (from my camera), and burn it onto a dvd - one for me, one for my friends in France -- Can I do this?
What do I need to do this? I'm presuming I need
1) something to make the video both NTSC and SECAM
2) be able to burn a Region Free disk
so... which is done by software, and which is done by hardware, and if anyone could give me some recommendations for what to get, I'd really appreciate it (and we're talking home budget, not big budget)
thanks, and apologize if I'm beating a dead horse here,
ferd
Results 1 to 11 of 11
no such thing as a secam dvd ... they use pal dvd instead ..
so make a ntsc and pal dvd ..... use procoder express , does a good job doing both ..
your disk will be region free with all standard dvd authoringware ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks for the reply
I'm confused tho, French TVs view content in SECAM format don't they? but they can also view PAL formatted DVD's? Is this a function of their DVD players? -
no such thing as a secam dvds ... they use pal for dvd disks there ..
it may be confusing -- but trust me on this ..
SECAM (Sequential Couleur Avec Memoire or Sequential Colour with Memory (or System Even Crappier than the American Method) color TV standard was introduced in the early 1960's and implemented in France.
SECAM uses the same bandwidth as PAL but transmits the colour information sequentially. SECAM runs on 625 lines/frame with the same framerate as the PAL does, 25fps.
SECAM is used in France, former French colonies and in former communist countries in Europe.
Because of its similiarity with PAL (same resolution, same framerate), all of the modern video systems, such as DVD, VCD and SuperVHS use PAL internally (for storing the data in the storage media, etc) and just change the color encoding to SECAM when outputting the signal back to SECAM TV."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
thanks again for your response!
Ok, last question - are there different varieties of PAL to be concerned about?
I'm presuming a Sony DRU710A, the bundled Nero and procoder express will get me where I want to go?
thanx again!
ferd -
those tools are just fine ....
yes there different pal versions but you will not be concerned about that ...
there are different ntsc and secam versions also if you want to know .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
another question...
I noticed a thread over here
http://forums.afterdawn.com/thread_view.cfm/81850
and they're talking like there's an extra step for Region free; Is this different from your experience?
ferc -
it is region free if you dont put a region on your authored dvd
ALL dvd authoring apps that are not professional level do not add regions -- and even with pro level authoring apps - you would have to tell them to do so ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
so there's no hardware aspect to the Region issue? When I install the DVD burner it's not going to presume or prompt me for my locale, and do anything ... counterproductive?
tia
ferd -
Originally Posted by ferdberfelThere are 10 kinds of people in this world. Those that understand binary...
How to make DVD in PAL and NTSC?
By perik in forum Authoring (DVD)Replies: 9Last Post: 19th May 2010, 14:18 -
PAL DVD work on SECAM?
By BobAchgill in forum Authoring (DVD)Replies: 3Last Post: 4th Aug 2009, 06:20 -
NTSC in an area where Secam is used?
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 2nd Jan 2009, 07:14 -
Newbie needs to convert NTSC VHS tapes to PAL DVD
By mcullen8320 in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2008, 13:51 -
Help! - ntsc and secam versions of chapter authored pal dvds
By devdev in forum Video ConversionReplies: 3Last Post: 25th Aug 2008, 21:05
