Results 1 to 9 of 9
  1. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Michigan (AP) - Michigan Internet users report a huge increase in the speed of there connections. Experts are still trying to pinpoint the exact cause but it only seems to last during the hours of 7 A.M to 3:30 P.M baffling some lead investigators as to it's cause.
    On a side note the server for the website videohelp.com has reported a drastic decrease in the bandwidth required during the same hours. Insiders report they are narrowing down the cause citing two specific forums Off Topic and the lesser used Feedback as being the ones with reduced activity.
    Investigator's there are in communication with the one's investigating the upsurge in connection speeds of Michigan residents trying to establish a link between the two but report there is nothing confirmed yet.
  2. Member Dr. DOS's Avatar
    Sep 2004
    Mid Atlantic
  3. Banned
    Sep 2004
    Inner Circle of Thought
  4. Originally Posted by thecoalman
    I thought it was because Yoda isn't around....
    j/k
    makntraks
    In the theater of the mind...
    It's always good to know where the exits are...
  5. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    j/k
    makntraks
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    Actually I worked till 4:30pm at my bank temp job :P :P
    AND I was using a corporate T1 line to do it so it wasn't affecting home users :P
    Kevin
  7. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Which leaves you a whole full hour to actually work.
  8. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    I worked! Just wasn't very busy there the last few months and the reason the assingment ended....
    Kevin
  9. Banned
    Sep 2004
    I worked! (
    Kevin
    A likely story
