  1. I know this is probably a silly question, but I'm pulling my hair out. How do I get my AIW Radeon to send a picture to tv out? I have all the cables hooked up (composite video and audio) but I get no signal to the tv. I am running WinME. Thanks for your help.
    Jul 2001
    Go to your ATI properties (control panel or whatever...) and you should be able to chose which display you want, TV or Monitor with one of the tabs.
    Dec 2001
    Well, i have the same card (ATI AIW Radeon TV out)and my cables go to my Video thrue a Scart !! Have you change the settings in "Display Properties" ??
    And i run it whit my L2 channel on my VHS !!
    Krille....................
  4. It should be rather simple. Right click on desktop, choose settings, select advanced, under one of the tabs there will be a selection for choosing monitor, TV etc. Fairly self explanitory once you get there. I'm at work now and don't recall the exact tab and setting to choose.
