Bruce,
Have you received your JVC HRS-9911 yet and had a chance to see how capturing from it compares to doing it all within the JVC DR-MV1S? For ease of use, setup, and space constraints, I'm considering going with the reputedly less effective all-in-one solution, even though I know the 9911 is supposed to be far better than the VHS section of the DR-MV1S.
Thanks,
Tim
Results 61 to 69 of 69
Tim,
Got the 9911 2 days ago. And yes, you can really tell the difference on older tapes. There is a improvement on the newer stuff I played with. I could see the difference, but my wife could not. If you source material is in good shape, and you have budget concerns, you will be happy with the MV1S alone. But, last night I compared the differnce on a 20 year old tape. This was the very first tape I ever recorded in a camcorder. To make things worse, it was not even a new tape when I recorded it. I was shocked last night when I did my capture. When the shots of my son ended, the next thing on the tape was an episode of 'Dallas' that was ending. So, I apparently took a tape that I repeatedly used weekly to record TV shows, and recorded my son over that. This tape played beautifully on the 9911, and I am so glad I had that over the player in the MV1S. So yes, the 9911 is the best way to go if you have the cash, and really old tapes. If you have fairly good source material, you may be happy with the combo unit alone.
One other thing though. When I recorded some tests with the combo unit, I did not like what it did during capture. When dubbing with the combo, the unit detects scene changes, and then breaks these up into differnt titles on the DVD. It does this by pausing the tape, and then backing it up to where the break was, then starting again. And, it does not to seem start recording in exactly the right spot. I did not like the way it did that, but some people may actually prefer it. When dubbing with a external VCR, it is just one continuous stream, because the combo unit has no control over a external VCR, and can't pause it to break up the recording. -
Thanks for the response, Bruce. Everything you say makes sense and I'm certain that I'll eventually have to get a 9911 or at least something close.
Most of our family videos are on high quality tapes, although many of them haven't been run through for a while. In addition, I have some important source material that has been heavily insert-edited and may be on tapes that were reused many times. I know I'm going to need good equipment for the latter, so deferring the equipment acquisition cost is only going to get me so far. I'd guess that I have 25 tapes that are from the 80's and maybe 50 that are from the 90's up to about 2001. I'm not sure that I'd back it all up digitally, but if it was easy enough I'm sure I would. Eventually, I'll want to edit the best stuff into new collections.
To get to that final point of having a good DVD recorder and a HRS-9911 or similar, from a cost standpoint I'd prefer to do it in a couple steps - as long as I wasn't spending more for something I wouldn't use after I get the 9911 or similar. How do you think the MV1S would compare to a good DVD recorder being fed by a standard VHS Hi-Fi VCR or a Hi8 camcorder going through a video stabilizer (VidiCraft PlayRight)? Do you think the MV1S would do better? If it's not all that much difference, what are some of the decent DVD recorders on your list?
As for the JVC HRS-9911, are there other less costly VHS players (I don't have any S-VHS tapes) that are nearly as good? What did you have on your final list?
Thanks for your help!
Tim -
Originally Posted by Bruce KuhnOriginally Posted by JVC america
I had to RMA my MV30as it had the Loading Bug. IF B&H refunds the money vs shipping a new unit, I will get a 9911 and a recorder.
I saw over internet that HRS-9911U has PAL capabilities. is it true ?
I'm not talking about JVC HRS-9911 , there's a 'U' added (PAL enable ??)"No, I Never feel anger for anybody. No human being can do such an important thing to make me feel anger."
Don Juan Matus. -
It's generally best to avoid combo units like VCR/DVD Recorders. Compromises are made to build them, and when one side of the unit breaks they are expensive to fix. Separate units are the way to go, and there is very little cost difference (unless you are getting a higher quality VCR, which would be preferable anyway).
Originally Posted by Mysticav
The "9911" is the HR-S9911U ... U stands for USA
No PAL.Want my help? Ask here! (not via PM!)
ok. I see, but gshelley61, as far as I know , this is not a combo!
Don Juan Matus.
HELP! looking for a stand alone NON-TV Capture unit
By lostinlodos in forum Capturing and VCRReplies: 9Last Post: 20th Jul 2011, 19:10 -
How To create new dvd's with menu's from existing ones from standalone unit
By bidelman in forum Authoring (DVD)Replies: 1Last Post: 6th Oct 2009, 16:01 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 10:45 -
trying to copy to dvd using standalone DVD unit
By Noek in forum Newbie / General discussionsReplies: 5Last Post: 18th May 2008, 14:09 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
