On my old G3 powerPc i could just open the side and clean out any dust that collected in it. I now have a G4 IMac and i dont see how i can clean any dust out that has built up in the past year.
My IMac is the model with the half circle base and chrome arm that holds the monitor.
Has anybody done this to their IMac?
Mark
Mark V
10.4.10 OS X 1.25GHz G4 768MB DDR SRAM Pioneer DVR-106D and external DVR-111D -
Mark, whatever you use to clean your iMac, never use a vacuum cleaner. It builds a static charge and can easly render your mother board DOA. Use only air from a can. You can buy this in any electronics store.
Good cleaning!20"iMac 2.0Ghz 1GB RAM : internal 250GB HD : 128GB Lacie FireWire d2 external HD : DVD-RW Lacie 4X d2 : iBot Firewire : OS 10.4.8 -
Does the IMac open easy?
Mark VMark V
If you have to ask that question, you should leave it alone. If you don't own pets, even less of a need to clean.
I have 2 dogs and a dusty house. I have taken electronics apart before so i know to be careful.
Mark VMark V
There has got to be some web pages which show you how to open that iMac, i know because my father used one to find out how to open and replace optical drive in the older imacs. One thing you could try is Apples new WEB CHAT SUPPORT
Go this this page and click on the
which says "Chat with a Support Agent. Apple is testing a new chat-based support service that’s available to iMac customers 24 hours a day, 7 days a week. If you need help, give it a try and tell us what you think."
then you can ask them how you clean it out
software for an imac
By marlo in forum MacReplies: 11Last Post: 13th Aug 2011, 08:49 -
DirecTV HD to iMac?
By jcoconnor in forum MacReplies: 0Last Post: 5th Apr 2009, 15:36 -
Problem with iMac G4 Speakers
By narevey in forum MacReplies: 2Last Post: 8th Mar 2009, 13:22 -
Dell or imac
By fairytale00 in forum ComputerReplies: 17Last Post: 29th Mar 2008, 12:51 -
Problem with imac G4
By matw79 in forum MacReplies: 1Last Post: 14th Jul 2007, 06:55
