I know, the title doesn't explain anything. But thats the best I can come up with for now.
I use Decryptor, Shrink, and Nero, to rip, shrink and write DVDs. Currently learning IFOEdit.
Here is my problem: Sometimes I mix two titles from different DVDs in DVD shrink and backup (reauthor mode). While I play the generated DVD I cannot use the NEXT button on my remote to go to the second movie.
I have to go till end of the first movie and wait for the second movie to start after a brief black out. I tried different options on Shrink to find a solution for this. nothing worked till now.
Is there a way we can achieve this? What software I have to use for this purpose.
Hope I made myself clear.
Thanks in advance.
Results 1 to 30 of 32
After Decryptor and Shrink, reauthor in dvdlab or tmpgenc dvd author, then burn in Nero.
Neither will re-encode, and dvdlab can actually import .vob's and join them if needed. You can change/add/remove chapter points also, if you want.Cheers, Jim
My DVDLab Guides -
http://home.tiscali.be/debie.roland/pgcedit/third_party/2cool/previous_chapter/intro.htm
that guide may helpbut I'm not 100% sure if it tells you how to jump to the next VTS. It can be done though but it may take a little learning but once you learn it's simple
if you want to know more and can't find an answer just ask and I will try to explain what you do when editing the commands and stuff as jumping movies is simple -
Thanks reboot & MackemX
MackemX's links is what I am EXACTLY looking for. Wonderful.
Well, I might need to learn a lot and might come up with quite a few questions.
Thanks once again. -
thats for jumping back to the previous movie using chapter skip or what I think it is. I don't see where it says it will jump forward to the next title but maybe it's in the guide somewhere
hope it is -
A large part of not being able to skip VTS is the player itself.
Sometimes the DVD specs can drive you nuts, but we have to do with it...
JeanlMenuShrink a free tool to shrink menus into stills with or without audio!
DVDSubEdit: a free tool to modify your subtitles directly inside the vob. -
can you not return to a Menu PGC within the current VTS then jump to another VTS that way?
Originally Posted by MackemX
It's a royal pain in the butt...
I'm confused, you are saying you can't jump to another menu?
I'm thought you can jump from a menu in one VTS to another VTS menu directly
http://www.dvd-replica.com/DVD/jumpss.php
Command: JumpSS
This command jumps to a PGC in the system space which can be one of the following:
First-Play PGC.
Title menu in the Video Manager.
Entry PGC in the Video Manager.
Root menu of a Video Title Set.
Subpicture menu of a Video Title Set.
Audio menu of a Video Title Set.
Angle menu of a Video Title Set.
Chapter menu of a Video Title Set. -
I'll check and get back to you!
OK Check this graphic. Does not seem to allow such jumps...
yeah, I see it but you can do it
. DVD LAB PRO also allows you to enter the VM command. I just created a test DVD using that. It plays the root menu from VTS 1 and the post command tells it to jump to VTS 2 root menu and it does
I tested the playback with PowerDVD (which doesn't say much) but then Mark's Tray DVD player also played it without complaining
guess they are wrong to allow it then
what's stupid is why be able to specify the VTS if you cannot go to another VTS? -
Ifoedit plays the DVD also but PGCEdit trace reports an illegal command
I guess the JumpSS VTSM command is only allowed in the VMG domain if that's the case. DVD players playing it still must just be a stroke of luck
if that's the case then it means DVDRemake shouldn't be allowing this command optoin in a VTS menu as Mark's Player not picking up the illegal command -
I'm amazed though, that you got it to work. I really thinks it's illegal... The ultimate test is on a standalone, I'll try that tonight...
MackemX,
I made a quick test and I can confirm that the JumpSS VTSM command is executed in PowerDVD, even when it's placed in the menu domain of a VTS. That's totally bizarre. I'll make a test on my standalone to see if it honors it or not...
strange isn't it
. Like I said I was expecting Mark's Tray Player to complain but it also played it without error
let me know how you get on with your standalone -
OK I can confirm that the command does work in my sampo standalone player. I can jump from the menu domain of VTS1, to the menu domain of VTS2 directly.
I'm not too sure what to make of all this...
Originally Posted by DoubleShadowIce
As well as to my Cyberhome that sees PUOs where none exist, and will sometimes refuse to acknowledge unlinked (to menu) tracks, or even skip from track to track when the NextPGC is set correctly.
Again, like I said, the player has some degree of control here.
Practice vs theory (and rules).Want my help? Ask here! (not via PM!)
Originally Posted by jeanl
@all, bottom line is the maybe the specs are there and going by those it's impossible. If one or and player doesn't follow them to the exact word, so that's we we get the differences of opinion as it then is possible (out of spec)
so it's another nobody is right and nobody is wrong
if you are reading this then you are either quoting me which is cheating or you have copied this text into a word document, which is it? -
I see your point. My understanding is that the spec is sooo confusing to begin with (I've had a chance to look at it, and it's a nightmare) that players indeed vary in the way they handle certain situations...
As far as jumping from one VTS straight to another one, I yet have to find one commercial DVD that does it without going through the VMG.
Anyway, I think we've beaten that horse to death!
Again, like I said, the player has some degree of control here. -
Large part, small part .... semantics .... it's a "part" that's important enough to be easily noticed and mentioned.
I don't need the DVD spec quoted to me, I know how it works. But I also know the player seemingly has some sort of "selective decision making" in how it reacts to discs. Many aspect are like this, from image quality to audio, etc.Want my help? Ask here! (not via PM!)
OK r0lZ (the author of PgcEdit) checked whether his Sony player allowed jumps from VTSM to VTSM and the answer is it does not. See this.
What would be the appropriate way to tell the author of DVDLab pro to fix this? I don't have the soft, and I don't know who the author is...
http://www.mediachance.com/contact.htm
the PRO forum is here
http://www.mmbforums.com/phpbb/viewforum.php?f=24
you may also want to contact Mark (Markham) about his player. He may just want to leave it the way it is but who knows -
Can you fit multiple movies on bluray media?
By rz514 in forum Authoring (Blu-ray)Replies: 12Last Post: 27th Apr 2013, 23:29 -
choice: burn to single BD, or multiple movies in 264?
By jlm86 in forum Blu-ray RippingReplies: 15Last Post: 20th Feb 2011, 20:14 -
900min in 1 DVD? Several hours/DVD? Multiple movies or tv-series/DVD?
By edvashas in forum Video ConversionReplies: 17Last Post: 29th Sep 2009, 03:16 -
Multiple avi movies on one dvd......portable dvd player that plays it?
By 9tinyfingaz in forum DVD & Blu-ray PlayersReplies: 15Last Post: 6th Jul 2009, 03:56 -
how to burn multiple DVD movies in one DVD
By jedy in forum DVD RippingReplies: 3Last Post: 8th Apr 2009, 04:51
