Two questions:
1)I purchased an Epson R200 inkjet printer to replace an old HP inkjet printer, and due to my home network configuration I also needed to replace my old print server with a new Hawking HPS12U print server. When the Epson R200 is hooked up directly to my computer via its USB cable, I am able to access all of the bi-directional functions such as ink levels, nozzle clogs, etc. However, when I hook it up to the Hawking HPS12U print server via the USB cable, I lose such functionality (all of these items are grayed out in the printing menu). Are there any settings on either device that I can change that will allow me to access these bi-directional functions when hooked up to this print server?
2)What have you R200 owners with experience found to be the optimum printer settings (ALL OF THEM) for CD/DVD printing? Rather than experiment with such settings, I would rather attempt to use those that you have found work well.
Thanks!
Richard W. Kutnick
VIDEO IMPRESSIONS
As I understand the Epson status monitor only works with a locally attached (USB or parallel) printer.
Info on Network Setup
http://files.support.epson.com/htmldocs/r200__/r200__rf/netwk_1.htm -
From Bodyslide's reference:
To monitor the status of a shared printer, EPSON Status Monitor 3 must be installed on each computer. EPSON Status Monitor 3 is automatically installed when you install the printer software for the first time.
Optimum x264 encoding settings
By zammil in forum Video ConversionReplies: 27Last Post: 18th Dec 2010, 00:32 -
Epson R380 Print Settings
By festeris101 in forum MediaReplies: 5Last Post: 20th Jul 2009, 11:41 -
Can you do a wifi print server via software?
By yoda313 in forum ComputerReplies: 4Last Post: 29th Oct 2008, 12:19 -
Installed R260 Epson, and the print CD keeps recognizing my old R200
By faramith in forum MediaReplies: 11Last Post: 2nd Dec 2007, 18:29 -
M2PMCEncoderZX optimum settings
By Kalash109 in forum DVD RippingReplies: 0Last Post: 30th Nov 2007, 12:52
