I am having this problem of direct burn to disc. The "record tape into DVD in one step" window in WinDVD creator is grey out.
I can select capture to harddrive ok. But not direct burn to DVD. This is the feature I thought it had, that was the reason I bought it.
Can anyone tell me if it is possible to do direct burn on this model.
Kai
Not sure with M401U but I've tried on M402U with Creator2. It works but the DVD menus created are something left to be desired.
To do this you have to go the wizard first and set all the necessary stuff including what audio format and and quality you want. If I can remember correctly - it has been a while since I did it. -
Thanks for the reply.
I got a Email reply from Plextor, they told me only the 402u can do direct burn to disks. The 401u can't.
Plextor ConvertX PX-M401U
By texasdontholdem in forum Video ConversionReplies: 0Last Post: 1st Jan 2010, 16:53 -
Any better capture devices than Plextor ConvertX tv402u?
By Heineken77 in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2008, 17:15 -
Plextor PX-AV200U ConvertX Digital Video Converter Updated
By BJ_M in forum Latest Video NewsReplies: 4Last Post: 3rd Jun 2008, 19:21 -
Plextor convertx px-m402u
By TyWelcome in forum Capturing and VCRReplies: 2Last Post: 18th Feb 2008, 22:43 -
I use the Plextor Convertx but with Premiere Elements, it don't werk!
By Heyjoojoo in forum Capturing and VCRReplies: 0Last Post: 21st Sep 2007, 20:02
