Right, bear with me on this one as I only vaguely know what I'm talking about. I recently discovered this GOP thing and I'm hearing a lot of talk on the net that if you optimise or edit the standard structure that you can acheive higher quality VCD's. Does anyone know know anytrhing at all about this?
Also, if somebody could give me any general tips regarding filters or whatever I can do to squeeze a bit more quality from a DVD to VCD rip I would be HUGELY grateful. I usuallly rip the vobs with DVD Decrypter, create a D2v with the DEFAULT SETTINGS for DVD2AVI 1.76 (i only change a couple of audio settings, encode to wave, 48khz to 44khz etc), load the d2v and wav into tmpgenc and then with motion search precision set to highest quality (what exactly isa this by the way), I encode.
Thanks in advance.
For some info on Motion Search in Tmpgenc, read this thread .
As far as changing GOPS to Improve quality in VCD, I doubt it. You can change the GOP in order to fit a little more playing time on a VCD by using less frequent I-Frames, but this will generally lead to a loss in quality.
Perhaps what you are looking for can be found at www.kvcd.net, this is the kind of thing those guys mess with all the time. Beware though, if you want to use the forums it is $2.99 to register!There are 10 kinds of people in this world. Those that understand binary... -
That was a very long time ago! They now use a maximum GOP size of 24 frames on kvcds, and kdvds are kept at a standard size of 15 for PAL and 18 for NTSC.Originally Posted by bugster
http://www.kvcd.net/portal/articles.php?lng=en&pg=20It's well worth it!Beware though, if you want to use the forums it is $2.99 to register!
As for AwesomeDude's question, if you use CBR, the longer the GOP the worse the quality.
Longer GOPs are usefull only on VBR encodings.
incorrect GOP when trying to author DVD with files extracted from VCD
By ibzomie in forum Video ConversionReplies: 2Last Post: 20th Jan 2012, 09:58 -
Multiple audio structures in same film using Ripbot264
By rocks911 in forum Video ConversionReplies: 1Last Post: 7th Dec 2011, 10:09 -
Which GOP program?
By pboong in forum Video ConversionReplies: 2Last Post: 16th Sep 2010, 12:19 -
Questions about GOP.
By Sean_ve99 in forum Newbie / General discussionsReplies: 11Last Post: 8th Jun 2007, 23:08 -
VCD to DVD (TDA error: GOP too long)
By jelir in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 09:40
