I have been using Adobe 6.5 yesterday I got imy systm formatted a nd installed win98se alongwith linux 9.Now My adobe does not render and gives me the following error messsge."Illegal operation..." Details"MCSPMPEG.AX at 018f:id204241" Can any body help me I have a project to complete.......![]()
nat_59
The word is "encode", not render.
Anyway, that is the MainConcept MPEG Encoder plugin error. Reinstall the "Adobe MPEG Encoder".Want my help? Ask here! (not via PM!)
Thanks Dear,
Now A Fifteen Min clipping with some effects takes 2 hour to encode.Before encloding I just wanted to confirm. Is it because of the processor 1.8ghz or anything else.I have a VCD and I want to add some effects and then encode and write.
akumarnat_59 -
Is there any other software like Adobe which can write faster with goodquality.
nat_59 -
You've gotta be specific in what you want...
Is it home movies, DVD rips, DivX downloads??
Is it captured material??
What is your final format??
Name all your tools used up to the problem point.. -
Uninstall your current Mainconcept encoder
Go to this site
http://www.mainconcept.com/adobempeg.html
You can download v1.2 or v1.3 here (1.3 works fine)
http://www.mainconcept.com/adobempeg/downloads.html
Or you can buy a v1.4 upgrade here
http://www.mainconcept.com/adobepromo.html -
Prem Pro CS 5.5 + Lagarith anyone? et. al.
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 14th Oct 2011, 14:13 -
Need help finding the right CS5 Prem Pro PC. Please help.
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 1st Apr 2011, 10:50 -
Vista Ho-Prem and versions of MSWMM
By wguru in forum Newbie / General discussionsReplies: 0Last Post: 10th Dec 2009, 18:47 -
no sound when i captured from dv in adobe prem cs. even hd didn't work
By cannibalcam in forum AudioReplies: 7Last Post: 5th Mar 2008, 07:07 -
Adobe Prem 2.0
By caeK in forum EditingReplies: 1Last Post: 1st Jul 2007, 11:21
