Hi, is there any way to repair a dvd movie that freezes in the middle? I used smartripper, dvd2avi and dvdfab to try any rip to my hd then fix the damaged vob, but no luck. The 3rd vob appears damaged. I get NO KEYS FOUND error in the 3rd vob, and when I select it with windvd I get "the file #1 has invalid format". Any ideas?![]()
You might try using DVD Decrypter to rip to hd, then try using a stream fixing tool like the one in VideoReDo, but there's no guarantee this will work, since other apps failed.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik
Frozen Memorex mvdr2102 DVD recorder
By flanmann in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Jul 2010, 05:40 -
Last few minutes of video frozen...
By JohnC1726 in forum RestorationReplies: 3Last Post: 14th Jan 2010, 09:56 -
Frozen frame when going from.mov to .flv?
By beanguy in forum EditingReplies: 1Last Post: 10th May 2009, 12:27 -
Philips DVDR 3350H - Frozen
By zukie23 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th Dec 2007, 01:35 -
usb2 mouse keeps frozen up after no using it over night
By deejay.2001 in forum ComputerReplies: 2Last Post: 13th Aug 2007, 18:42
