This is the first time i've encountered this problem and i can't think of any reason why this is happening.
After I rip the 16:9 dvd (i've tried both dvd shrink and decrypter) and view the rip with media player or windvd, the movie looks just like the dvd would on my tv, with black bars at the bottom and top.
but when i prepare it to encode with xvid, whatever app i use to encode with stretches the image vertically to cover the top and bottom black bars. it does it in dvdx, dvd2avi, whatever. and the stats always still show the vid as being 720 x 480, which it is, but with bars missing for some reason so that the image stretches to fit 720 x 480.
the majority of the time i either use dvdx and set crop to custom/selection so that i can crop the black bars and still keep the original aspect ratio. or i prepare to frameserve to another app with dvd2avi. but in both apps, the file is shown without the bars for some reason.
i've tried everything. why is this happening?
Results 1 to 11 of 11
maybe it is an anamorphic file. this will use 720 x 480 frame size with a widescreen aspect ratio, and it will look exactly like you say.
thanks. i was about to serve to vdub and go through resizing and cropping filters. i think your option sounds easier.
well, the par configuration didn't work, so i used vdub filters instead. if i were to do this again, which resizing option would be the best to use? bilinear, bicubic, precise bicubic, or lanczor?
If the DVD was encoded at 16:9 (regardless of the final AR) the horizontal of the avi should be 852 wide to keep the correct aspect ratio (16:9 enhanced mpeg2 enododings are 33% wider than standard 4:3 encodings YET contain no extra information..ie they are still 720 X 480...so using 852 would be pointless unless you want maximium height, 480).
Try this GUIDE (you can swap SmartRipper for DVDDecrypter if you want) and remember install all the software as given at the top of the page:
http://www.nanomessiah.com/dvd-backup/dvd-to-xvid.html
HTH -
thanks for the tip, but the problem was that the vid was an anamorphic file and i didn't even realize it. dumb me.
Crop/Remove black bars without re-encoding?
By agent154 in forum Blu-ray RippingReplies: 55Last Post: 22nd Aug 2015, 20:06 -
Adding black bars
By ebay in forum Video ConversionReplies: 4Last Post: 7th Aug 2010, 04:37 -
Black Bars
By cinnamonhearts2 in forum Newbie / General discussionsReplies: 15Last Post: 30th Jul 2009, 12:44 -
black bars or not?
By Cowabunga in forum Video ConversionReplies: 6Last Post: 16th Apr 2009, 12:56 -
Need to cut off black bars
By Dozza in forum EditingReplies: 8Last Post: 2nd Sep 2007, 07:17
