I have already started to use the
Plextor PX-M402U ConvertX Digital Video Converter to get old PAL VHS onto my pc and compress to DVIX 5.2.1. But the video I have (PAL) is mono. So I only had the left output onto it. i was only playing it on my TV to see the results in DIVX and they were impressive (Video) but I realized then audio was only comming from the left channel !.
I checked further and realized the right channel is CLEAN and left channel has all the audio.
Is there a simple way to make the Divx Mono and use one channel ? so when played both speakers play it or copy the left channel to right with out having to extract it and do the copy and reinput it ?
Whats the fastest way to do it ?
Thanks in advance
Results 1 to 11 of 11
You'll have to fix the audio then remux the new audio with the video.
Here's how I'd do it:
Load your AVI into Goldwave and follow the instructions here. Save this out to a new WAV file - this will be our new audio source and it should have two channels if you've followed the above link correctly.
Open your AVI with virtualdub, go to Audio > WAV audio and specify the WAV as your audio source. Go to Video > Direct Stream Copy, then Go to Audio > Full Processing, then go to Audio > Compression and set it to MP3 with whatever bitrate you want. When finished setting ewverything up, go to File > Save AVI, and save out to a new AVI file. This will directly copy the video and join it with the new WAV file, while converting the audio to MP3 as it goes. Your new AVI should have two channels now.If in doubt, Google it. -
Originally Posted by goden99
-or-
Head to your local electronics store and pick up a mono to stereo Y adapter. It's a simple plug with 1 rca adapter on one side and splits it two on the other. -
RCA "Y" cable adapters work for me. Connect left to the single point of the "Y" and the other two points of the "Y" left and right.
If you really want convenience, you get a switch and connect the left output of one side of the switch this same way and the other side of the switch normally. -
I looked at all the options and there is nothing about the mono but i like the Y adapter Idea. I am going to do that for all the other things I am going to capture but for what I have i will do the jimmalenko method
I have captured a few tapes 5 tapes mutiplied by 210 minutes.
I have a few other tapes too capture
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 11:32 -
AC3 File: Audio only on left channel
By koberulz in forum AudioReplies: 10Last Post: 25th May 2011, 12:07 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 11:54 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 16:47 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 00:45
