Hi,
I was trying to make a SVCD, and I managed to make it, that's not my problem, but under the "Other Setting" of the project wizard, for the video arrange method, I picked "no margin, keep aspect ratio". I thought this would stretch it to the full screen, while keeping everything intact, but I noticed that it cut out quite a bit from both vertical sides. My question is then, since the "No margin" option cuts out from the edges, what's the difference between "Full Screen, keep aspect ratio" and "Full screen, keep aspect ratio 2"??
you may be seeing overscan on your tv and thinking that tmpgenc is at fault ...
it's not -- tv's cut off a lot of the picture
if that is not what you are talking about -- sorry .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Naw, it's not the TV, cause after I watched it and noticed that a bit of the opening credits were cut off, I checked the SVCD file on windows media player and it was cut off there, so it musta been from when I converted it into SVCD, becuase the original file was fine. I think it was because I did the no margin option.
TMPGEnc Authoring Works 4 no video
By quxote in forum Authoring (DVD)Replies: 5Last Post: 3rd Apr 2013, 23:48 -
TMPGEnc Video Organizer
By TBoneit in forum EditingReplies: 8Last Post: 14th Dec 2012, 20:28 -
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
Converting Video for a Blackberry using TMPGEnc
By Vachoen in forum Video ConversionReplies: 3Last Post: 9th May 2008, 16:06 -
Tmpgenc producing Jerky video?
By love2learn in forum Video ConversionReplies: 7Last Post: 11th Nov 2007, 09:37
