I have a Lite-On LDW-411S which has worked great until recently. All burns are failing regardless which software I use. I'm using the same software and media that I used when burns were succeeding.
I'm wondering if anyone with a bit more experience can tell me what might have gone wrong based on the log I'm including. The errors appear to be at the end of the log, but I don't understand how to read them.
One odd thing I'm noticing in the log is that it's saying I'm using Nero 6.3 when I'm using 6.6.0.5.
Code:Windows XP 5.1 IA32 WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 10:03:20 AM ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/2003 7:18:06 PM Nero version: 6.3.1.10 (Nero Express) Recorder: <LITE-ON DVDRW LDW-411S> Version: FS0K - HA 3 TA 0 - 6.3.1.10 Adapter driver: <atapi> HA 3 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ATAPI CD-ROM: <LITE-ON DVDRW LDW-411S >Version: FS0K - HA 3 TA 0 - 6.3.1.10 Adapter driver: <atapi> HA 3 === Scsi-Device-Map === DiskPeripheral : Maxtor 6Y120M0 atapi Port 1 ID 0 DMA: On CdRomPeripheral : LITE-ON DVDRW LDW-411S atapi Port 3 ID 0 DMA: On CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 4 ID 0 DMA: Off CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 4 ID 1 DMA: Off === CDRom-Device-Map === LITE-ON DVDRW LDW-411S D: CDRom0 AXV CD/DVD-ROM E: CDRom1 AXV CD/DVD-ROM F: CDRom2 ======================= AutoRun : 1 Excluded drive IDs: CmdQueuing : 1 CmdNotification: 2 WriteBufferSize: 83886080 (0) Byte ShowDrvBufStat : 0 EraseSpeed : 0 BUFE : 0 Physical memory : 1022MB (1047548kB) Free physical memory: 676MB (693104kB) Memory in use : 33 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 10.1.2005 UDF/ISO compilation 6:28:11 PM #1 Phase 112 File dlgbrnst.cpp, Line 1841 DVD-Video files reallocation started 6:28:11 PM #2 Phase 114 File dlgbrnst.cpp, Line 1841 DVD-Video files reallocation completed (no file modified) 6:28:11 PM #3 Text 0 File Isodoc.cpp, Line 6065 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : FALSE Allow more than 255 characters in path : FALSE Write ISO9660 ;1 file extensions : TRUE 6:28:11 PM #4 Phase 111 File dlgbrnst.cpp, Line 1841 DVD-Video files sorted 6:28:11 PM #5 Text 0 File Reader.cpp, Line 118 Reader running 6:28:11 PM #6 Text 0 File Writer.cpp, Line 124 Writer LITE-ON DVDRW LDW-411S running 6:28:11 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3899 First writeable address = 0 (0x00000000) 6:28:11 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3899 First writeable address = 0 (0x00000000) 6:28:11 PM #9 Text 0 File Burncd.cpp, Line 3200 Turn on Disc-at-once, using DVD media 6:28:11 PM #10 Text 0 File DlgWaitCD.cpp, Line 244 Last possible write address on media: 2297887 (510:38.37, 4488MB) Last address to be written: 2286095 (508:01.20, 4465MB) 6:28:11 PM #11 Text 0 File DlgWaitCD.cpp, Line 249 Write in overburning mode: FALSE 6:28:11 PM #12 Text 0 File DlgWaitCD.cpp, Line 2107 Recorder: LITE-ON DVDRW LDW-411S, Media type: DVD-R Disc Manufacturer: MCC 01 - RG20 Disc Application Code: 64, Disc Physical Code: 193 6:28:11 PM #13 Text 0 File DlgWaitCD.cpp, Line 410 >>> Protocol of DlgWaitCD activities: <<< ========================================= 6:28:11 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 813 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (CTransferItem) 2 indices, index0 (150) not provided original disc pos #0 + 2286096 (2286096) = #2286096/508:1.21 relocatable, disc pos for caching/writing not required/required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286096 blocks [LITE-ON DVDRW LDW-411S ] -------------------------------------------------------------- 6:28:11 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 982 Prepare recorder [LITE-ON DVDRW LDW-411S ] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681924608, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ 0 | lead-in | 0 | 0x00 | 0x41 0 | 1 | 0 | 0x00 | 0x41 0 | 1 | 1 | 0x00 | 0x41 2286096 | lead-out | 1 | 0x00 | 0x41 6:28:11 PM #16 Phase 24 File dlgbrnst.cpp, Line 1841 Caching of files started 6:28:12 PM #17 Text 0 File Burncd.cpp, Line 4210 Cache writing successful. 6:28:12 PM #18 Phase 25 File dlgbrnst.cpp, Line 1841 Caching of files completed 6:28:12 PM #19 Phase 36 File dlgbrnst.cpp, Line 1841 Burn process started at 4x (5,520 KB/s) 6:28:12 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2345 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 6:28:12 PM #21 Text 0 File DVDR.cpp, Line 1650 Recording mode: Sequential Recording Mode 6:28:12 PM #22 Text 0 File Mmc.cpp, Line 20051 Set BUFE: supported -> ON , SMART-BURN : ON 6:28:12 PM #23 Text 0 File DVDR.cpp, Line 1791 Start write address at LBA 0 DVD high compatibility mode: Yes 6:28:12 PM #24 Text 0 File Cdrdrv.cpp, Line 8024 ---- DVD Structure: Physical Format Information (00h) ---- Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD-R (2), Part Version: 5 Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 0 h End Sector Number in Layer 0: 0 h Data in Burst Cutting Area (BCA) does not exist Start sector number of the current Border-Out: 0 h Start sector number of the next Border-In: 0 h Media Specific [16..63]: 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 6:28:20 PM #25 Text 0 File Cdrdrv.cpp, Line 1291 18:28:20.031 - LITE-ON DVDRW LDW-411S\H3 T0 : Queue again later 6:42:52 PM #26 Text 0 File WriterStatus.cpp, Line 115 <LITE-ON DVDRW LDW-411S > start writing Lead-Out at LBA 2286096 (22E210h), lenght 0 blocks 6:42:52 PM #27 Text 0 File ThreadedTransfer.cpp, Line 229 all writers idle, stopping conversion 6:42:52 PM #28 Text 0 File DVDR.cpp, Line 2001 EndDAO: Last written address was 2286095 6:49:26 PM #29 SCSI -1176 File Cdrdrv.cpp, Line 1185 SCSI Exec, HA 3, TA 0, LUN 0 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x72 Sense Qual: 0x02 CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0x71 0x00 0x05 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x72 0x02 6:49:26 PM #30 CDR -1176 File ThreadedTransferInterface.cpp, Line 1701 Session fixation error 6:49:26 PM #31 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1701 Could not perform end of Disc-at-once 6:49:26 PM #32 Text 0 File DVDR.cpp, Line 2001 EndDAO: Last written address was -1 6:49:26 PM #33 Phase 38 File dlgbrnst.cpp, Line 1841 Burn process failed at 4x (5,520 KB/s) Existing drivers: File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 7/17/2002 9:05:10 AM File 'Drivers\PXHELP20.SYS': Ver=2.03.01a, size=20368 bytes, created 9/1/2004 5:30:45 PM (Prassi/Veritas driver for win 2K) File 'Drivers\atapi.sys': Ver=?.?.?.?, size=95360 bytes, created 8/4/2004 12:59:42 AM (Adapter driver for rec) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Bazooka is right, so don't throw the burner out the window yet.
Discs often tend to go bad toward the outside. Keep your file size at (or below) 4.2GB and try a different brand of disc like Maxell, Fuji, & TDK. -
If it's reporting the wrong Nero version, it could be a DLL conflict, or a registry glitch, or any number of other such problems.
Try completely uninstalling Nero -- including going into regedit and removing all keys under HKEY_LOCAL_MACHINE\Software\Ahead and HKEY_CURRENT_USER\Software\Ahead (if any still remain) once Nero's uninstall is complete, then deleting the entire C:\Program Files\Ahead directory (if it still exists after the uninstall).
Once you're sure no traces of the program remain, reboot the system and re-install Nero from scratch, and see what that does for you. -
1. Do a defrag
2. Dont do stuff on the pc while you are burning
3. slow down the burn
4. Try using DVDecrypter instead of nero for your burn. Personally, I would just use dvddecrypter, but I am suggesting using dvdecrypter to rule in/out nero -
flash and convert your liteon 411 drive to a liteon 811 with the zebra mod patch....check the LITEON FORUM at cdfreaks.com
Computer failing?
By dylz in forum ComputerReplies: 11Last Post: 13th Mar 2011, 04:08 -
Failing to get 16:9 display!
By osmancik83 in forum Newbie / General discussionsReplies: 1Last Post: 27th Nov 2010, 18:46 -
Failing burner?
By Constant Gardener in forum DVD & Blu-ray WritersReplies: 2Last Post: 3rd May 2010, 12:57 -
is my cpu failing
By lordhutt in forum ComputerReplies: 12Last Post: 19th Dec 2009, 20:11 -
mkvextract failing
By Paratoxic in forum Video ConversionReplies: 2Last Post: 28th Nov 2009, 17:08
