I have been making mostly VCD's from my VHS tapes over the years just to save some $$ instead of making DVD's.... But now i need to m ake some high quality DVD's...]
Could some people here suggest the best applications in doing this.. most of the DVD's i want to make are 80-90 mins long. I want them to look as great as possible. I have attemped using a few diff ULEAD products such as Videostudio and Movie Factory. I cant seem to have any luck though. I know i want the rosultion bigger.. Plus on a program like the Pinnacle Studio 8.8 If i choose mpeg. it automatically chages to VCD ..dunno why...
the standard DVD templates used in either of those apps is 720x480 which is the highest you can use.Originally Posted by Evhmoon
That's cause you need to choose mpeg2, mpeg can be used on DVD but it uses the VCD standard exclusivley.Plus on a program like the Pinnacle Studio 8.8 If i choose mpeg. it automatically chages to VCD ..dunno why...
As LS pointed out above there's plenty of articles and tutorials explaining exactly how and what you need to do. I suggest you start in the What Is section and read over the DVD specs. -
You can't make the output look any better than the input.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 02:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
