-recorded a short clip with NeroVisionExpress (DV Type-2)
-tried to open in VirtualDub and recieved this message:
Couldn't locate decompressor for format 'DVSD' (unknown)
VirtualDub requires a video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable.
What do I do?
Nero's pdf help says it uses DirectShow codecs, and Virtual Dub does not support the use of those codecs. Maybe VDub didn't want to pay Microsoft royalties. DirectShow supports constant bit rate only(which is why the Windows Media Player won't play most mp4's). Nero's software is probably using vbr for better compression. Installing the DivX 3.11 codecs may solve the problem. They are hacked codecs with MS sigs to fool Windows. They might fool VDub too.
But the same thing happens when I capture with Win-DV and try to bus over to VirtualDub.
So, what do I need to do to be able to edit my avi. files in VirtualDub? Capture with VirtualDub? That sounded problematic/difficult to set up.
What editor is there that does accept DirectShow filters? -
You might want to have a look at the entry for dvsd at fourcc.org.
It would suggest to me that you don't have the right DV codec installed.
What does gSpot say about your AVI file? It should tell you about what codecs you have on your system for DV.
cheers,
theDruid.
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Error Message
By Perfik in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Jul 2007, 12:45 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16 -
Error Message
By Kallid in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 15th Jun 2007, 20:13
