If you do there is a little section on the left side of the prog that does automatic overclocking, well my FSB is default at 204 and when i clicked the Automatic OC, it starting going up. when it reached 224 i stopped it, I wasnt sure whether to go on or stop b/c this is a new cpu and i dont want to wreck it. I wasnt sure if it would automatically stop or should i click stop when i want it too? Any Help?
Their overclocking apps will keep going until the processor reboots. The system will remember what speed it maxed out at. I forget exactly where it is (my app is a little different because I have an Intel chip) but once it hits the limit and you reboot you should be able to choose that max speed again. You can also adjust it manually to any speed below what it maxed out at. Mine goes much higher than 150, but that's where I choose to keep it (default is 133). Once it's done the testing for overclocking I just changed the FSB value to 150 and clicked save. Now whenever I want it OC'd I just click the turbo button in the Fuzzy Logic app.
Nothing can stop me now, 'cause I don't care anymore.
Recovering quiet audio
By ReedJohansson in forum AudioReplies: 6Last Post: 20th Mar 2012, 06:03 -
Need A Quiet Blu Ray Player
By V Bot in forum DVD & Blu-ray PlayersReplies: 7Last Post: 15th Feb 2011, 15:55 -
Need a new psu - a quiet one
By persephone in forum ComputerReplies: 7Last Post: 13th Dec 2010, 17:35 -
VOB2MPG Quiet Audio
By gfinlay in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Apr 2010, 04:28 -
Pioneer DV-610AV, quiet or not?
By rimbaud in forum DVD & Blu-ray RecordersReplies: 0Last Post: 6th May 2009, 04:13
