Newbie question: when I encode DV video to DVD, should I turn on deinterlace? The DV video is interlaced.
Thanks!
Results 1 to 10 of 10
What if I have a progressive DVD player and TV?Originally Posted by jimmalenko
I don't know to be honest.Originally Posted by cheerful
Read this though:
http://www.digitalfaq.com/capture/interlace.htmIf in doubt, Google it. -
Quote:
Progressive-scan DVD players add an important additional step to create a better-looking picture — they generate a progressive-scan video signal through a process called de-interlacing (sometimes called "line-doubling"). The de-interlacer's first task is to look at the interlaced video signal as it leaves the MPEG decoder and determine whether its original source was 24-frame-per-second film or 30-frame-per-second video. The original frame rate determines the type of processing necessary to create an optimized progressive-scan signal.
:unquote
So if you de-interlace you throw away half the fields reducing what can be used to optimize the picture.I think,therefore i am a hamster. -
NO!
Your tv and DVD player will handle the video. You don't worry about that. It does the work for you. Leave it interlaced.
"Progressive scan" is not progressive.Want my help? Ask here! (not via PM!)
One more question: which media player is good for playing back interlaced mpeg on PC? What about playing to TV (nVidia card)? Will it look bad?
Thanks!
Deinterlace
By leftspeaker2000 in forum DVD RippingReplies: 2Last Post: 5th Dec 2011, 06:17 -
Deinterlace?
By ZedsDead in forum Video ConversionReplies: 6Last Post: 15th Mar 2010, 00:21 -
To deinterlace or not deinterlace...
By Nilfennasion in forum MacReplies: 4Last Post: 4th Dec 2008, 01:46 -
Do I need to deinterlace? Or never deinterlace?
By rbatty11 in forum Video ConversionReplies: 12Last Post: 17th Jan 2008, 14:15 -
What Deinterlace does in Avi2Dvd?
By geek2330 in forum Newbie / General discussionsReplies: 2Last Post: 24th Jun 2007, 21:51
