Hello can any one tell me how to rid my computer of Adtomi.I run adawre it always finds it,i use the function to delete it,but on all future scans it is always back.I understand now there is no unistaller availiable for Adtomi.
My question now how do i get into the registry to remove this and will there be any trouble removing the reg key?
Do you have system restore turned on or off?
If it is on than that is why it keeps coming back. -
Ok now im peeved,i turned of system restore,ran adaware,removed adtomi .Shut off computer for a few hours,ran adaware again and they are still there in registry??This is the details,when it comes to registry im at a loss.>>
Vendor:Adtomi
Category:Malware
Object Type:Regkey
Last Activity:14-01-2005
Risk Level:Low
TAC index:5
Comment:
Description:No uninstaller. Masks operation.
Vendor:Adtomi
Category:Malware
Object Type:RegValue
Location:clsid\{a78860c8-ee1a-46df-a97f-e3e6d433e80b} ""
Risk Level:Low
TAC index:5
Comment:
Vendor:Adtomi
Category:Malware
Object Type:Regkey
Risk Level:Low
TAC index:5
Comment:
Do you know a way i can manually delete them?
Thanks -
To go to the registry, click Start, Run, type Regedit, OK
Hightlight My Computer, Edit, Find, type Adtomi
Every time you find an occurrence of Adtomi, delete it until you see the message like regedit has finished searching the registry.
Then, do a search for the key a78860c8-ee1a-46df-a97f-e3e6d433e80b
Edit, Find a78860c8-ee1a-46df-a97f-e3e6d433e80b
Delete every occurrence of it.
Close regedit.
People are scared of the registry, but if you do it correctly, it's as safe as clipping a toe nail.
Next, start Internet Explorer, Tools, Internet Options, General
Choose Delete Cookies, Delete Files and Clear History
Malware are very sneaky, search google for Spysweeper, let it search your HD for malware and destroy them.
Good luck.
Dan -
Thanks that solved itTo go to the registry, click Start, Run, type Regedit, OK
Close regedit.
Will keep this as a reference now.Frightening experience though
Emsisoft Anti-Malware
By Teac23 in forum ComputerReplies: 4Last Post: 11th Apr 2011, 08:55 -
Videora now full of MALWARE!
By Putana in forum DVD RippingReplies: 6Last Post: 4th Oct 2010, 12:25 -
Malware from SUPER?
By Yamitora1 in forum ComputerReplies: 6Last Post: 6th Mar 2010, 21:43 -
Adaware Shows Replay Media Catcher As Malware
By DarrellS in forum ComputerReplies: 3Last Post: 5th Mar 2009, 01:51 -
adaware 2008 or spybot?
By jyeh74 in forum Newbie / General discussionsReplies: 7Last Post: 30th Jul 2008, 09:14
