I have been trying 2 programs all afternoon and no having any luck. I have tries DVD2SVD and the film machine and they both seem complicated. How many different times do you have to convert the data to get it to burn with Shrink or Decrypter. Im I totally lost or do you have to convert the AVI to MPEG and then the MPEG to a VOB or am I getting totally screwed up. I can seem to get the audio to convert but at the vedio part whare the program goes to TMPGenc it just stops.
AVI-video to m2v/mpv, audio to ac3/mp2/wav then AUTHOR to vobs etc
or
AVI to mpeg, then author to vobs etc.
You need to understand the basics first (there is no shortcuts, sorry) and the possible problems you may/will come across. Its NOT hard to grasp at a basic level but you need to learn...one click apps will help you by about 0%
Read the GUIDES and the FORUMs -
VSO DivxToDVD will convert your AVI file to DVD Vob files very easily. Then you can burn them with Nero or and I think DVD Shrink will work as well. Give it a try. About the easiest program to use. You don't get a lot of choices, but it's fast and easy.
http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm might help you.
If in doubt, Google it. -
guy, you can use the tool xilisoft video converter to rip .avi file to .vob file, then burn it with your burn program. Find it at https://www.videohelp.com/tools?tool=Xilisoft_Video_Converer.
Converting AVI to other format.
By abozny in forum ffmpegX general discussionReplies: 3Last Post: 11th Apr 2012, 07:46 -
converting Dv-Avi/Dvd Mpeg2 to Xvid format
By glenpinn in forum Video ConversionReplies: 56Last Post: 9th Jun 2009, 09:23 -
a good tool for converting avi or divx to the dvd vob format?
By extent in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2009, 13:37 -
Problem converting avi to dvd format with Avi2dvd
By bgart13 in forum Video ConversionReplies: 0Last Post: 13th Apr 2008, 16:27 -
In need of help with converting .mkv to .avi format
By nabeelnk1 in forum Newbie / General discussionsReplies: 2Last Post: 31st Dec 2007, 15:47
