BeSweet has a nasty reputation of making incompatible AC3 streams from other formats. I need an app+directions on how to convert any audio stream that can be contained in an AVI/OGM/MKV container to AC3. Otherwise, settings on how to get BeSweet to output the AC3 files properly would be good too
The current process I use is either demuxing the audio (or save wav) in VirtualDubMod > Convert to AC3 with BeSweet and useing AC3 fix before remuxing. Works most of the time, but it often doesn't.
Results 1 to 30 of 41
well - what ac3 encoder are you going to buy ?
then we can give instructions on how to use it .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
why ? uses the same ac3 encoder doesnt it ?
1) neoDVDPlus converts AVI video to DVD structure with AC3 audio in it, ready to burn to DVD directly. If I just want the AC3 audtio, then I use VobEdit to demux the VOBs files to AC3 and M2V files. The last two can be re-authored again with a different software to get better menu, chapters etc...
2) reelDVD software takes MP2 or WAV and encode to AC3
--------------------------------ktnwin - PATIENCE -
Getting the software isn't a problem, so long as it does the job. I'm sure to use it often. I only need it to convert audio as I use TMPGEnc Xpress to reencode the video part.
Seeing as VirtualDubMod can demux any audio stream to wav, reelDVD can convert it to DVD compliant AC3? -
If price IS NOT an issue, pay someone to do it for you..................oh, and lose that silly picture, what are you a 14 year old kid with an identity problem?
What results problems have you had with TMPGEnc's AC3 encoder? I get great results with it (and it's not just because I've been a pro recording engineer for 37 years - it's because it's an excellent encoder).I don't encode Audio with TMPGEnc Products, it's not their specialty. I'm more concerned with results rather than price
I use the TMPGEnc Xpress AC3 plugin to convert all my audio streams to AC3. I usually use it while converting DV but have used it to convert audio only in a couple instances.
If price isn't an issue buy Vegas 5+DVD.
monzie is right...get rid of that picture. -
TMPGEnc Xpress AC3 plugin is fine -- ALL lic'd dolby encoders are checked by dolby and use a common back end .. but different front end and some pre-proccessing ..
Pic's gone, was too big. I want to be able to do it myself, I won't be paying others.
I've had considerable sync problems when encoding both audio and video with TMPGEnc Plus/Xpress, that's why I always do it seperately. Since doing so I haven't had any sync problems, only the BeSweet compatibility problems.
ReelDVD's an Authoring app, no? I'm looking more for something that's main purpose is audio editing/encoding etc. Sony Vegas+DVD Production Suite is looking good. I'll be checking that out.
As for the TMPGEnc Xpress AC3 plugin, you've never had sync problems? -
Not once. And I make a lot of DVDs for clients who are re-selling them so they have to be maximally compatible.As for the TMPGEnc Xpress AC3 plugin, you've never had sync problems?
I also use Sony Vegas 5 but I frameserve out of it to TMPGEnc XP3 and then author with DVD-Lab (both of which accept the TMPGEnc AC3 plug-in). -
Thank you, I appreciate the help, I have both the AC3 plug-in and Sony Vegas+DVD PS, sadly there aren't many guides around for this software. Off to do some testing.
There are a lot of good Vegas guides/tutorials around. Here's a good starting place:
http://www.blue7media.com/vegas/ -
Yeah just search Sony Vegas tutorials on Google and 100's will come up.
Originally Posted by Ecko_Blue
tons of guides -- as well as the manual .... even right on thier web site in the download section"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
you buy software for 600$+ and have no idea how to use it ?
http://www.martyhedler.com/homepage/Vegas_Tutorials.html?Welcome_Visitor=1054421711
http://www.jetdv.com/tts
http://www.vegastrainingandtools.com/
http://www.wideopenwest.com/%7Ewvg/tutorial-menu.htm
http://users.rcn.com/rofrano/Video/video.html
http://www.luciferjones.org/kick%20start%20to%20Vegas.htm
http://www.creativecow.net/articles/vegasvideo.html
http://www.sundancemediagroup.com/home1.htm (link to guides on page)
http://www.dmnforums.com/cgi-bin/disp.fcgi?dire=4&prog=displaywwugindex.fcgi&endday=1&...-foundry_vegas
http://www.mediasoftware.sonypictures.com/forums/ShowTopics.asp?ForumID=4
http://www.creativecow.net/index.php?view=s&forumid=24
http://s92274348.onlinehome.us/vegas.html
http://www.rmtools.se/
http://midihead.servehttp.com/
http://www.endor.demon.co.uk/
http://www.creativecow.net/articles/vegas_scripts.html
http://www.debugmode.com/"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Whoa. Thanks BJ_M. As for the $600, software's easy to come accross.
I appreciate the links
For 2 chanel (AC3 or MP2) then FFMPEGGUI is worth its weight in gold (and its feeware)....but only use its DEFAULT settings (192) as this setting seems to be the most tolerant and will work on 99.99% of all mp3 vbr's (dont ask me why as I DO NOT KNOW..it just works..no synch problems).
same non lic'd , non complant issueOriginally Posted by monzie"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
well some of us that do this shit for a living have to pay for our software ..
As far as I am aware the non compliant issue was fixed ages ago in ffmpeg/liba52.
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 17:14 -
BeSweet for 4.0/quad AC3?
By RogerTango in forum Video ConversionReplies: 1Last Post: 17th Nov 2011, 04:16 -
Problem with BeSweet/BeLight. Trying to batch convert Ogg Vorbis to ac3.
By rayden54 in forum AudioReplies: 9Last Post: 30th Dec 2008, 19:37 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 07:49 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 11:46
