It is thought by many (including me) that there is very little difference in end quality (to the point where it's not really noticable) when using the very slow (highest quality) setting, but the increase in time that it takes to do this is phenomenally longer than using motion estimate search. I'd suggest you do a couple of 1 minute samples with each and see the differences in both time and quality for yourselfOriginally Posted by deanst2![]()
Results 31 to 37 of 37
If in doubt, Google it.
Sounds good.
I also noticed you chose the lower resolution, as opposed to the 720x480. Do you do this most of the time? -
Originally Posted by deanst2If in doubt, Google it.
Thanks! Wonder if I could pick your brain again. I've been encoding the way you recommended without probs and putting on to DVDs and suddenly ran into a problem with an .avi.
I used TMGenc to encode and it goes through the encode process, for video only, but when I go to play it I get a blank screen although I can tell something is running and the counter is moving?
This same .avi I noticed would not run in Media Player but Nero's showtime player was able to run it?
When I tried to use TMGenc wizard and encode video and sound together I got a result with a dark image but sound was playing.
Any theories or suggestions or solutions.
THANKS! -
Originally Posted by deanst2"Art is making something out of nothing and selling it." - Frank Zappa
Tried it and failed. I still get audio and no video...I can see some artifact on the dark screen as if it begins to play but then stops....although the counter says differently...open to any suggestions.
This is so frustrating since everything was working fine!
TMGEnc Xpress - no sound
By deanst2 in forum Authoring (DVD)Replies: 3Last Post: 2nd Jun 2010, 17:27 -
TMGEnc Xpress Not enough memory issue
By hawk123 in forum Video ConversionReplies: 0Last Post: 10th May 2010, 18:21 -
audio encoding: tmgenc dvd author 3 vs. tmpgenc plus
By cL0N31 in forum Newbie / General discussionsReplies: 0Last Post: 6th Jan 2009, 23:25 -
TmgEnc DVD Author Menu Problem
By powerkoala in forum Video ConversionReplies: 9Last Post: 25th Sep 2007, 13:19 -
Tmgenc DVD Author
By powerkoala in forum Video ConversionReplies: 10Last Post: 19th Sep 2007, 06:02
