Could anyone tell me why I get no sound when I play the mpeg I converted from avi with the above prog.
Is it a codec I dont have to play the sound or something that is going wrong with the encode.
Many thanks for your kind help
Need more input, need more input.... I know I just tried converting a DivX encoded .avi to an mpg and didn't have any sound as well.
Yes thats what I have discovered the AVI was Divx.
I tried it with a small ordinary avi and had sound.
I am conducting further experiments.
Wonder if there is anyway of returning the DIVX avi to ordinary AVI
Please, if you figure it out, can you email me and post a solution. I've been trying to get this to work. I have several DivX movies I want to convert to mpeg so I can output them through me Dazzle DVC II, but they need to be mpeg first (with sound)
Try doing this, I now have a working VCD with sound
Most DivX movies come with MP3 or WMA audio compression. Unfortunately, most of the AVI to MPEG-1 conversion tools do not support compressed audio, so the only way to convert DivX to MPEG-1 with audio is to decompress the audio first.
You can do this using VirtualDub - there are two methods :
Decompress audio within the AVI file
1. Load your DivX/AVI file into VirtualDUB.
2. From the "Video" menu, select "Direct Stream Copy".
3. From the "Audio" menu, select "Full Processing Mode".
4. From the "Audio" menu, select "Compression" and choose "No Compression (PCM)".
5. Save the AVI file
Then use your Ulead to convert as you did before, then burn it to cd.
I have tested it on computer DVD but not stand alone.
NO sound when capturing with Ulead SE 11
By TheKillerQueen in forum Capturing and VCRReplies: 41Last Post: 13th Mar 2012, 03:55 -
Ulead DVD Video Studio 10 editor
By Steveold in forum AudioReplies: 1Last Post: 27th Apr 2011, 04:54 -
Sound out of sync in ulead video studio..
By iames85 in forum AudioReplies: 5Last Post: 24th Apr 2011, 05:10 -
Capturing sound with Easycap/Ulead?
By lacyxsummer in forum Capturing and VCRReplies: 2Last Post: 7th Dec 2009, 02:07 -
No sound on ULEAD Video Capture
By bagshot48 in forum Newbie / General discussionsReplies: 8Last Post: 17th Oct 2008, 11:18
