I'm getting this error when I try to load an avi into virtualdub
Couldn't locate decompressor for format 'DIV3' (Microsoft High Speed MPEG-4 V3 [Hack: DivX Low-Motion])
Virtualdub requires a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable.
..how can i fix this?
What do you mean by normal? Yes, whenever you are missing a VFW codec the normal response from VirtualDub is to give you an error message. No, if everything is working correctly you don't get error messages.
I do have FFDShow installed, but I still get the same error from Virtualdub.Originally Posted by celtic_druid
Do I have to configure FFDShow for Virtualdub somehow?
Thanks -
Yes, installing DivX_3.11 solved the problem.Originally Posted by junkmalle
Thank you.
I want use x264 codec in virtualdub but i can't
By Hugo12317 in forum Video ConversionReplies: 5Last Post: 6th Jun 2011, 13:41 -
Codec for VirtualDub
By TheGame111 in forum EditingReplies: 4Last Post: 21st Dec 2010, 20:05 -
Cedocida DV codec with VirtualDub
By tsu3000 in forum Newbie / General discussionsReplies: 1Last Post: 26th Nov 2010, 15:32 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10
