Hi
I need a advice to choose between Nec 3520 and LG GSA4160B.
What is the preferred DVD writer and why ?
Thank in advanced
Results 1 to 14 of 14
Need DVD-RAM support? Go for the LG.
Need bitsetting capability? Go for the NEC (you will need a firmware patch). -
I believe (not 100% sure on this) that you can "flash down" the 4160 to the 4120. You lose the 16x speed for the 12x, but you get bitsetting support.
-Yar, matey!- -
From what I have read, you cannot Flash down to the 4120.
The LG 4160 burner sets DL disks by default to DVD-ROM. So not having a bitsetting option is probably not that big a deal. However, bitsetting can be useful for DVD+RW disks. But mots people use DVD+R for burning DVD-Video. Bitsetting DVD+R disks is possible but rarely necessary.
The newer LG 4163 model allows bitsetting. -
Bitsetting of everything (I mean +R and +RW), or only of DL disks?The newer LG 4163 model allows bitsetting.
SHouldnt he just buy the 4120 then instead?Originally Posted by Kingnog
Well i know the 4120 can be "flashed up." I just didn't know the difference between the 4160 and the 4163...
-Yar, matey!- -
NEC, I tried the 4120B, the discs skip on some players. The first LG lasted 16 discs before it died. I use the NEC 3500 every day, perfect burns every time.
I've had 2 LG's (the 4040 and the 4120) and both worked (still works) very well
-Yar, matey!- -
I trade discs with other people, so they were played on many different players, some had problems with LG discs, none have ever had a problem with NEC discs.
NEC ND-4550A Problem
By drakster in forum DVD & Blu-ray RecordersReplies: 3Last Post: 3rd Jul 2010, 13:25 -
NEC AD-5170A Questions
By urb1972 in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Nov 2007, 21:39 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 22:07 -
NEC 4571A problem
By rmorrison1 in forum DVD & Blu-ray WritersReplies: 18Last Post: 1st Jul 2007, 13:35 -
NEC NDH81
By babagoi in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 20:05
