I sometimes capture from TV to "time shift", recording them to DVD-RWs. Spending the time it takes to author with most authoring programs and then burning seems like a waste of time.
Does anyone know an authoring/burning program where basically you can drag and drop a compatible MPEG and then burn with a single click (or at least with only minimal effort)??
TIA
fREBieware- you get what you pay for.
Just about any aothoring program will come close. Pick a template for DVD, drop the clip in the first play slot and burn away. Use a app such as Ulead Movie Factory that has a selection for "do not convert compliant files".
Thanks for the quick response. I apologize for the delayed thanks....
fREBieware- you get what you pay for. -
ReJig. Great for the fastest dvd from mpeg ever
Cheers, Jim
My DVDLab Guides
(Mp4, AACv2, MKV, Webm, Theora) Drag Drop Convert GUI Update v 1.2.0.0
By richter03 in forum Video ConversionReplies: 11Last Post: 21st Apr 2013, 06:35 -
Drag and Drop Assets
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th May 2011, 05:37 -
AVC H.264 MP4s displayed black by VirtualDub upon drag'n'drop
By bulgom in forum EditingReplies: 22Last Post: 6th Apr 2011, 21:18 -
Drag n Drop Problem
By Jim255 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 29th Mar 2011, 04:26 -
Author tool that allows for drag-n-drop template authoring?
By jlietz in forum Authoring (DVD)Replies: 2Last Post: 16th May 2007, 13:54
