hi![]()
svcd images in bin, cue files,extracted the files using iso buster, filter mpeg2 files to folder. tried loading, drag and drop into trmpg enc cut and merge to join the files no joy. tried mounting in deamon tool and using svcd2dvd but says no bin in drive, but it is there, tried dragging the files into dvd lab and tmpg authorising but no look, the files will play in divdx player so the files are o.k. I'm tring to convert the files to dvd and authorise. also is there a way of altering the field settings in tmpg to change screen size for dvd pal 704*576?
any ideas![]()
many thanks
Get virtualdubmod, open the mpg, frameserve to your encoder (tmpgenc) adjust as needed, re-encode.
Author in dvdlab.
Alternatively, you could just author the svcds in dvdlab. Guide in my sig.Cheers, Jim
My DVDLab Guides
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
bin files
By fredreed in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2009, 01:02 -
recover files from recycle bin
By Tbag in forum ComputerReplies: 5Last Post: 25th Jul 2008, 07:16 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
