How to remove region code of dvd-writer or dvd-rom?
I can only choose to change it 5 times, and i guess it will lock to the last changes.
You would need a hacked version of the DVD-Rom/Writer firmware. There may be some other tool for this though.
get two readers , one for each region .. they are like what $18 now or something ...
If I am not mistaken, you can actually rip any dvd from any region. The region checking is just for playing that dvd in a player (set top, software, etc). Is this not correct?
Yes, I guess ripping is no problem. Playing only, I just think DVD Region+CSS FREE will do the trick.Originally Posted by smearbrick1
IMHO. -
Yes firmware will do. Ill settle with software first.Originally Posted by smearbrick1
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 10:26 -
Region Code Samsung ht-bd1220 - Code does not work
By mhschenk in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Oct 2009, 15:44 -
Need code for pioneeer bdp lx70 code for multi region ...
By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 13:42 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 05:34 -
Remove region code?
By hiimbored in forum DVD RippingReplies: 12Last Post: 6th Jun 2007, 23:55
