Hi guys,
which one is the best dvd ripper ? (speed and quality)
DVDXCOPY or DVDShrink ?
Thanks.
Results 1 to 20 of 20
DVD Decrypter. Even faster with AnyDVD enabled at the same time.
Hmmm... that's interesting. So you're saying that not only is there no conflict between DVDDecrypter and AnyDVD, but that they actually work very well together? That's good to know, because it answers one of the questions that I had been wondering about for a while.Originally Posted by HatchetMan
Yup. DVD Decrypter will rip faster because the disc will not show up as encrypted, so less work for Decrypter.
Guys, I just tested Decrypter and it's indeed very fast, but is it able to change the bitrate to fit a dvd in 4.7G ? Shrink does that but I didn't find any setting for this in Decrypter. Did I miss it or it's not there ?
It's not there. DVDDecrypter is just a ripper, and a ripper only. DVDShrink is a ripper and transcoder, while DVDXCopy is just a transcoder now AFAIK, as is DVD2One. Load the ripped files into DVDShrink and let it do it's thing
If in doubt, Google it. -
DVD Decryter + DVD Shrink = love
Seedin and encoding... Healthy pc life :) -
A formidable combo, yes.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Indeed. Before I heard of DVDShrink and DVDDecrypter, I used to believe free software was free because there was something wrong with it. Not that I wouldn't contribute to the development cost if I could afford it.
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
OK, one last thing:
-please tell me why it's better to rip with Decrypter and shrink it after with DVDShrink instead of going straight with DVDShrink doing two things in one shot. Is it about the quality ? -
Nothing at all to do with qualityOriginally Posted by vanderbog
It is generally quicker, and DVDShrink has been known to choke on certain discs, whereas DVDDecrypter does the job on just about any disc you throw at it.If in doubt, Google it. -
DVD shrink can compress all movies on D9 disc to D5 DVD-R?Originally Posted by ckamc
There are almost no films that DVDShrink cannot transcode to a 4.35GB disc, and of those it cannot, they're all films that are more than three hours in length. I've even managed to get films that were originally over seven gig in size to fit on one 4.35GB disc, although the picture quality left something to be desired. The only discs that I have failed to transcode using the DVDShrink - DVDDecrypter combo, so far, I have failed because of physical problems with the source disc (CRC errors and the like).
Has anyone used #1 DVD Ripper? Seems to be getting a lot of positive press lately...
-87W -
The compress movie can be played using what player? or do we need to uncompress it back?Originally Posted by Nilfennasion
Besides what jimmalenko already stated, it saves wear and tear on your DVD-drive. Especially when using deep-analyst. Since with DVDshrink the DVD drive runs through the entire process. Where as using DVDdecrypter your Drive is only in use for the ripping process (8 - 15 min), and DVDshrink does all of its work from the hard drive.vanderbog wrote:
OK, one last thing
Deek -
When you burn it to a disc, the transcoded movie can be played back in anything that is compatible with the disc format.
Put it this way... say you put a two-hour film onto a DVD+R as your standard DVD-Video file structure. The only thing that will limit what you can play it back on is compatibility with the DVD+R standard."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
DVD Ripper
By lexus22 in forum Newbie / General discussionsReplies: 3Last Post: 13th Apr 2012, 12:49 -
Using All-In-One DVD ripper
By shuohshuoh@trashmail.net in forum DVD RippingReplies: 2Last Post: 11th Apr 2010, 13:47 -
Best DVD ripper?
By nj473 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Mar 2010, 16:42 -
DVD Ripper Suggestions
By Steverup in forum DVD RippingReplies: 1Last Post: 23rd Oct 2007, 12:14 -
dvd ripper
By not_aplicable in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 22:53
