Hi,
Does anyone know of a free tool, library, bit of code that will give me format info of an MPEG2 file? Basically this is for a bit of software and I want to check to see if an existing file is compatible with my output format to decide if it needs re-encoding.
Thanks.
Results 1 to 9 of 9
There are 10 kinds of people in this world. Those that understand binary...
Thanks, but that's a GUI tool. I need either a command line program with a simple output, or a library.
mpgtx has an information mode. It is an opensource tool, so you should be able to look to see how it retrievies its information.
http://mpgtx.sourceforge.net/ -
Well C++, but I can probably figure it out from other stuff.
Is there not a simple header in a .mpg file? -
Well you can use MediaInfo:
http://sourceforge.net/projects/mediainfo/
DLL, library etc.
or DirectX, depending on what your application target is, which has lots of interfaces for this.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Send me a PM with your e-mail, I can send you my VB6 code and some add Info.
Or have a look here (in the Source code section):
http://www.gromkov.com/tutorials/soft_links.html
need help finding the best container/codec Format for my situation
By staeberc in forum Video ConversionReplies: 7Last Post: 17th Feb 2011, 16:42 -
Finding out the duration of an MPEG file
By firblazer in forum ProgrammingReplies: 4Last Post: 20th Oct 2010, 01:55 -
Which format produces better quality overall MPEG-2, MPEG-4 or .x264?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 31st Aug 2009, 03:00 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Finding/Reading Video Format
By jkassen in forum MacReplies: 3Last Post: 16th May 2008, 08:37
