I have loaded in a video file into VirtualDubMod and merged in the subtitles file (*.srt). I not want to save the video with the subtitles merged in. However, it asks me to choose a codec for the saved video. Which is hte best one to choose (apart from the highly space consuming "uncompressed") which would give me lossless quality from the original avi file? I heard someone suggesting DivX 5.1.1 with the highest quality and "Home Theatre" options. But the "Save As" action also gives a tick-box for "old VFW 1.1.e compatibility" option. I don't know if this overrides whatever other codec I choose (eg the DivX 5.1.1). If so, I wondered if VFW 1.1.e is a more lossless conversion than DivX. Or can someone please suggest something?
Any advice is most appreciated.
Thanks.
Results 1 to 9 of 9
DivX is surely not lossless. Huffyuv is the alternative to undcompressed.
/Mats -
huffyuv (excluding the one in libavcodec/ffdshow) doesn't support YV12 though (and there is a fairly decent chance that the source is YV12), although if you are adding subs with VDubMod then it is converting to RGB anyway.
Why exactly do you want to save out a lossless file? If it is because you want to then re-encode it to something else, then I would suggest instead frameserving with AVISynth. -
Originally Posted by celtic_druidThere are 10 kinds of people in this world. Those that understand binary...
Thanks. -
No, that's the best way of doing it. Once set up correctly, you can do lots of nice things with your AVI (like resizing, filtering and stuff) before frameserving it off to your encoder.
/Mats -
I (n00b being :P) think it's better to NOT put in the subtitles in the AVI, but put it as a BUP on the DVD.. If you rip your movie from DVD once and want to put other subtitles on it, you can't, because you put the subtitles in that movie...
Originally Posted by The Celestial Celebi
I think what you mean is to author the DVD with a selectable subtitle stream, rather than encode them as part of the video.There are 10 kinds of people in this world. Those that understand binary... -
Originally Posted by mats.hogberg
. Since VDub converts input to RGB before working w/ it, you could end up losing color detail. also, this adds overhead to the conversoin time. so, hte best way is prolly more along the lines of avisynth, altho as soemone mentined before, it may not be worth learning the new tool if time/unnoticable loss of color quality is unimportant. i just remember that when i made my switch from VDub to AVISynth, CCE encode speed went from somewhere around .84 to somewhere around 1.05
my two cents
Recommend a <$100 capture card for analog to lossless AVI codec
By Cheesyii in forum Capturing and VCRReplies: 8Last Post: 27th Dec 2011, 08:49 -
missing mp3 audio codec in ulead when saving as avi
By gabz in forum Video ConversionReplies: 3Last Post: 24th Jul 2011, 16:23 -
Deinterlacing MiniDV AVI file and saving as lossless AVI
By Dave2ic in forum Video ConversionReplies: 3Last Post: 27th Dec 2010, 15:11 -
Do Movie Maker or Virtualdub re-encode DV-AVI when saving? Quality concern?
By sdineen in forum Newbie / General discussionsReplies: 9Last Post: 18th Jul 2009, 21:47 -
DVD to AVI - Lossless Quality?
By tikigod19 in forum DVD RippingReplies: 6Last Post: 11th Sep 2007, 05:03
