Hi!
I have a little problem with DVD Lab.
I did whole project, ready to compile DVD.
After DVD was compiled I checked the Video_ts folder only to find
5 files:
VTS_01_01
VTS_01_02
When I opened my Power DVD only main movie played without any menu,or short movie segment.
I did everything right,never had problem before,but now I can't find a mistake.
Do you have any idea what can be wrong??
Results 1 to 9 of 9
Cheers, Jim
My DVDLab Guides -
I think I did it everything right.
Actually when I open Power DVD IFO file is missing.Only those 5 VOB files are present.
When I tried other DVD player I got straight my movie playing but without the menus.
I never had a problem before.I did only 3 DVD's but without problem like that.
What information I should give you so you can picture my problem.
Thank you guys for your time -
Had the same problem the other day with a project.
I kept modifying the same project (which must of picked up a bug) and just went from frying pan to frying pan.
I couldnt fix it until I started from scratch again. -
Had the same problem and posted here too...
https://www.videohelp.com/forum/viewtopic.php?t=252054
So far I've not found a solution. -
are you selecting play DVD from Hard Drive and then locating the IFO? You should not be able to see any VOB's when browsing with PowerDVD.
You will only see them if you select to play media files. You will not see IFO's either when you select this option
you need to get hold of Mark's Tray DVD player. Version 2 onwards only works with a registered version of DVDLAB and not as a standalone like the previous versions did. This is an excellent analysis program and most times should be able to show exactly where it's going wrong -
I had the same problem with WinDVD6, it only plays main movie.
WinDVD Platinum (a year older) plays exactly like the dvd should.Cheers, Jim
My DVDLab Guides
More dvd lab questions
By sterankin in forum Authoring (DVD)Replies: 12Last Post: 16th Aug 2010, 17:13 -
Help with DVD-lab PRO.
By angles in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2010, 18:19 -
DVD Lab question
By sumeshkri in forum Authoring (DVD)Replies: 5Last Post: 13th Nov 2008, 22:32 -
DVD Lab 2 error
By XL3/\/7 in forum Authoring (DVD)Replies: 4Last Post: 3rd Jun 2007, 07:54 -
DVD Lab Help!
By ardiani in forum Newbie / General discussionsReplies: 14Last Post: 25th May 2007, 08:52
