capturing with the MJPEG compressor codec.
i set quality at 50% and did not compress audio as specified by one of the tutorials and the file size of the capture is HUGE!!
using virtual vcr as the main capturing device should i compress audio?? if i do what audio compression method should i use??
thanks to anyone who helps me out.![]()
When you are capturing dont compress the audio,use pcm,when you encode then compress the audio.The file size will be large but when you encode then it will be much smaller.
Help please:Virtual VCR crashes on startup
By cgarai in forum Capturing and VCRReplies: 10Last Post: 11th Apr 2012, 15:53 -
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 01:54 -
Please help: Virtual VCR not detecting Audio Device
By cnfcnf in forum Capturing and VCRReplies: 6Last Post: 30th Jan 2011, 13:17 -
Is it possible to capture like this? (Videogame related)
By fathertadpole in forum Capturing and VCRReplies: 4Last Post: 20th Mar 2010, 11:47 -
Virtual VCR Trouble - Error 80070003: Cannot start graph
By MJDore in forum Capturing and VCRReplies: 2Last Post: 10th Mar 2009, 20:12
