  1. Hi,
    I am trying to multiplex a .m2v and a .ac3 with mplex.
    mplex -f 8 -o "done.mpg" "video.m2v" "audio.ac3"
    **ERROR: [mplex] Need to split output but there appears to be no %d in the filename
    This is an old problem that was supposed to be fixed.
    See:
    https://www.videohelp.com/forum/viewtopic.php?t=210853
    I have version 2.2.2 2003/05/13. Is this version still too old or is there possibly a problem with my m2v or ac3 files?
    Thanks, Squeeto
  2. Free Flying Soul liquid217's Avatar
    Feb 2002
    its not a bug. Mplex has detected some 'end of stream' markers in the m2v file and wants to create a separate file for the next segment. You can remove the 'end of stream' markers with restream. Also see here for a related subject.
  3. This is true- I joined a few .m2v films together using BeSplit.
    BeSplit -core( -input video.lst -prefix video.m2v -type m2v -join )
    Do you think I should be talking to DSPguru next?
  4. Maybe it is something that I did in TMPGEnc.
  5. Aaahh. ReStream did the trick and DVDAuthor didn't complain either.
    Thank you Liquid217.
    Did I make a mistake along the way (a setting in TMPGEnc maybe) that I could correct so that I don't have to restream? Maybe BESplit adds the end of sequence codes.
  6. Free Flying Soul liquid217's Avatar
    Feb 2002
    If besplit is the last tool you used before using mplex, then i would guess that it added them. Im not really familiar with besplit, so i really can't help you with that.
