I'm looking for a free program that will convert HTML files with Links and Images to a .EXE file, Anybody got any ideas where I may find one? Preferably easy to use ,I will only need it maybe twice.
Thanks.
Not sure if this is what your looking for but Photoimpact can create self extracting exe's for HTML Albums or slide shows. It's really as simple as selecting your sourc images setting the parameters and clicking ok.
Really simple to use.
I can put an example up for you if you want. -
Originally Posted by thecoalman
Very interesting, Yeah that would be great. Thanks -
Here's a quick link, http://www.nepadigital.com/temp/main.html there's lots of options. Thumbnail creation, slideshow, resizes the images from the source automatically to your settings. This one auto advances after 5 seconds. No thumbnails.
Can be exported as EXE, there's a ton stuff, took like 5 seconds to createw this one. -
Well it's specifically for creating web albums quickly, there's buttons at the top for next,previous image. When you make one with thumbnails it auto creates the links from the thumbs. You can't convert existing pages.
If you wanted links you could always insert them into the HTML yourself. Photoimpact will create HTML pages, not sure if it integrates with the slide show though. I've never used it for HTML as I have better apps for that. -
Here is what I was looking for , Cant seem to find a free one.I quess I will buy it.
http://www.aw-soft.com/webexe.html
How to convert producer powepoint file in HTML to mp4 video?
By smgrif0 in forum Video ConversionReplies: 1Last Post: 31st Dec 2010, 07:57 -
How to Convert RAR HTML Files Into A Movie File
By raven120461 in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2009, 11:35 -
An html question, how can we insert images to fit into table cells ?
By lana2000 in forum ComputerReplies: 5Last Post: 27th Feb 2009, 13:39 -
HTML: mp3 links to webpage other than white?
By bourboner in forum ComputerReplies: 1Last Post: 30th Sep 2007, 19:28 -
how convert .exe video to another for zoom/still
By oregonpi in forum Newbie / General discussionsReplies: 8Last Post: 2nd Aug 2007, 18:42
