I'm fairly new to burning dvd's and although I've been burning with Japan made TDK's, I've noticed during playback that some of them are kind of screwy. Is there a program out there that tests the quality of a burn? I'm assuming a bad burn is what causes the movies to freeze, stutter, etc, etc. Like I said I'm fairly new, so if there's any other information I should be aware of about this issue, please let me know. Also, are these issues that could mostly be resolved by using TY or Maxell media?
Thanks,
Chris
That's interesting, how can you tell it's bad?
Also is their any quicker way, seems the speed program is in real time....2 hours, watchin the movie works too..
Thanks -
No it's not. Takes 10 minutes to run a SCANDISC.
www.nomorecoasters.com and read instructions there.Want my help? Ask here! (not via PM!)
Thanks for the help using Nero tools.
Is it possible to have a bad file that causes bad burns. Seems some movies are find and others have read errors, yet other movies burn and read ok? -
Defrag the hard drive.
A fragmented drive can cause problems.Want my help? Ask here! (not via PM!)
i'm pretty new to making dvds to, only started cause i got a nu laptop with a dvd write too. i made my first dvd direct from hdd, but when i played in my sony, it didn't fwd and rewind well in play back. next attempt i made a DVD image (*.iso), & have had no problems so far, using the same cheapo media & the free burning s/w provide by supplier!!!!! :P
note: create a NTFS partition on your HDD so you can actually have a 4.7 GB image!!!!!
Is VLC a fault-INtolerant VOB PLAYER for pre-DVD-burning quality testing?
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 5Last Post: 16th Aug 2009, 21:52 -
Getting a better quality burn
By brado09 in forum DVD RippingReplies: 6Last Post: 24th Apr 2009, 11:59 -
Check quality of burn
By amerifax in forum DVD RippingReplies: 8Last Post: 18th Mar 2009, 21:34 -
Quality reduction on Burn
By barkingcat in forum Authoring (DVD)Replies: 20Last Post: 24th Mar 2008, 08:58 -
Video Quality Testing Software
By stevel61 in forum TestReplies: 9Last Post: 30th Oct 2007, 05:15
