Is it ok to put labels on the DVD or does it effect the disc.
If it's ok what label kits would you recommend, if not, what would you recommend to just do the cards in the jewel boxes, I have an HP Laser Jet printer.
What kind of pen can write on the discs, everyone I've bought won't.
Poker TV Guide http://www.go-poker.com
https://www.videohelp.com/forum/viewtopic.php?t=138166
Better make yourself a cup of coffee to read that one cause its long. But I think it has all the information you are looking for.
In the past I used Sharpie pens to write on both CD and DVD media with no problem. Now I use the Epson R200 to print on inkjet printable media.
There are lots of different kits for printing out inserts for DVDs and Jewel cases. They are all pretty much comparable as far as I can tell unless you are looking for a specific type of paper (matte v. glossy.) If it were me, I'd just pick up one of the kits that Rima.com offers. -
I use the Memorex label system. Print the labels with my Epson color printer.
I have done several hundered DVDs with very little trouble.
I am very careful to make sure that the labels are COMPLETELY dry and then apply useing the Memorex tool.
Good, high quality Brand name media works best (you get what you pay for).
I know that many people have problems with such labels. I dont. -
The only time in my opinion is when there isn't much on it...Originally Posted by chole
Sounds silly, but the only time I use adhesive labels on my DVD's now is for my demo reel. 10-15 minutes long. Not much taken up on a DVD. I even go to the added, albeit crazy length, to slipping the labeled disc into a CD envelope, putting it into the middle of a hard cover book and stepping on it just to make sure it is firmly pressed on.
For anything like movie/data backup, I wouldn't bother. I'd just go with a black sharpie.
Windows OEM Preinstallation Kit (OPK)?
By videobread in forum ComputerReplies: 2Last Post: 14th Nov 2011, 15:53 -
Smith Victor K76 light kit
By ProducerHarley in forum Newbie / General discussionsReplies: 8Last Post: 29th May 2011, 22:52 -
CD/DVD has ripped label, how do I fix it?
By videohalp in forum Newbie / General discussionsReplies: 6Last Post: 12th Apr 2009, 06:20 -
need psd template for cd/dvd label
By wingfan in forum MediaReplies: 3Last Post: 22nd Dec 2008, 13:25 -
dvd Duplicator kit
By crocker5731 in forum DVD & Blu-ray WritersReplies: 21Last Post: 2nd Nov 2007, 18:15
