I am trying to create a menu for on a DVD that I want to burn with AVI and Mpeg files. I have tried with ULEAD but when I create the menu my files then take up 3 times more space. So if I try to burn a 700 MB AVI file with a menu it takes 2.1 GB.
Is there a way to create a menu that won't take that much space? All I really want is a data CD with a menu at the beginning. What program can do this?
Any help is much appreciated.
Data CD with a menu will not work on a DVD player, only the Computer. I think you want to make a SVCD.
This is what I have used. There maybe some free ones over in the tools.
www.cdmenupro.com/ -
I don't think it's possible. Ulead knows that AVI is invalid for DVD, so it is converting your video to MPEG-2 to make a DVD out of it, that's why it's 3 times as big. I have never heard of this, but maybe DivX people have figured out a way to make menus work for DivX. If it works for DivX, you can make it work for what you want. DivX is just one type of AVI. You might go to a DivX forum and ask if it's possible to make interactive menus for DivX.
Well, there was the MicroDVD project:
http://www.divx-digest.com/software/microdvd.html
The idea's to play AVIs back as if they were DVDs. I think this might be what you're looking for.
H.T.H/\/\ars /\/\ayhem
Help: Freeware for basic DVD menu from VIDEO_TS/VOB
By pannayar in forum Authoring (DVD)Replies: 11Last Post: 12th Aug 2008, 03:17 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
Creating Menu's
By wristar in forum Authoring (DVD)Replies: 4Last Post: 10th Oct 2007, 19:42 -
creating a DivX menu
By shankie in forum Authoring (DVD)Replies: 14Last Post: 29th Jun 2007, 11:28 -
Help to finish a basic DVD project with menu, chapters and videos?
By mikeli in forum Authoring (DVD)Replies: 4Last Post: 29th May 2007, 11:11
