I have this drive and it's running patched 1.16 firmware. I tried to flash to 1.18 patched firmware and I keep getting the message "unable to open J: drive". This is the correct designation for my drive (confirmed in Windows XP). I did use captital J also. The drive was empty (I left it open). I tried all sorts of permutations of "dvrflash -v J: R......., etc. I confirmed the files and dvrflash are in the root directory (cI've tried the official Pioneer firmware and, of course, it wouldn't flash cause I was running patched firmware.
What can I do?![]()
Problem solved!
I used the wrong dvrflash file. Of the three created (dos, win32, linux), I used the dos one by mistake. I got confused since I was using the dos prompt in windows. Anyways I was at the end of rope and replaced the dos file with the win 32 one. Lo and behold, my drive flashed.
Note to self. Write down directions step by step and file away. Don't rely on over 40 year old brain cells to remember.
Flashing went wrong with my DVP5992/37
By chiquito3 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 2nd Apr 2010, 20:56 -
Problems with flashing colours on VHS/SVHS capture
By nick1977 in forum Capturing and VCRReplies: 20Last Post: 5th Mar 2010, 07:09 -
Flashing Arrows To Emphasise
By Squid_uk in forum EditingReplies: 10Last Post: 13th Mar 2008, 23:17 -
Pioneer DVR520 - Flashing Timer Icon on Display - Not Working
By canon10d in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Oct 2007, 19:19 -
Pioneer DVR-107D mistakes certain DVD+R/DVD-R discs as "blank CD"
By litmus in forum DVD & Blu-ray WritersReplies: 3Last Post: 5th Sep 2007, 14:38
