ok, i've been searching the forums (and the web) regarding this topic and there seems to be a lot of different ideas on getting this to work (DivX Doctor II, joining via Quicktime Pro, etc.). so, i'm hoping, once and for all, we can come to some sort of conclusion on the best way of going about this.
The Situation
I have two .AVI files which, when combined, make up a single movie (ie. movie has been split into two parts, one per AVI file). I would like to combined/join these two files to make a single file that can then be
a) stored as the single file for playing via MPlayer, Quicktime, etc.
b) later burned to DVD (thus, will need to run file from a) through ffmpegX to create DVD burnable file(s).
so, basically, i need to come up with a way of joining these two AVI files resulting in a single file (for use on my laptop) that can also, later, be converted and burned as a DVD.
any help would be greatly appreciated!
regards,
kristin.
Results 1 to 14 of 14
Originally Posted by major
thanks again!
kristin.
in quicktime you can use the quicktime script "start movie 2 with movie 1"
movies do not have to be same format.
the easiest editor to use is simplemovieX. try it, you'll like it. you can edit mpegs and not re-encode. also able to join disimilar moviesG5 2ghz x2 1g ram, alchemy tv card, 200 g lacie firewire hd, formac studio dv/tv, eyetv 500; a PC and a series 2 TIVO
Everybody talks about joining DivX files with ffmpegX as if it works fine so I'm assuming it does for everybody but me. Whenever I join two DivX files it claims to have been successful but though the resulting file plays in VLC correctly when I try to play it in Quicktime it cuts off half way through the second half. Sadly they do the same in my stand alone LG DivX player when I burn them to DVD. can anyone offer any suggestions on this or point me to any past threads concerning it. (I'm New) I've done a seach but it havn't come up with anything so far
Ok Thanks that seems a possible reason, If it's the case then it should be affecting others apart from me. If any one could feedback on if they've managed to get two files of DivX (with AAC or MP3 sound. within an avi file) of around 700MB joined together and the result to play fully in Quicktime or on a stand alone player please let me know what your settings were. Or is it impossible?
I've joined them successfully in Quicktime and then saved it but it obviously saves as a Mov. file this plays great in Quicktime as you'd expect but won't on the LG DivX player. simply changing the extension to avi doesn't work. putting it through ffmpegX again with everything set on passthrough doesn't work for me either.(though I've read somewhere here that it's worked for others) it produces either an empty avi file or it changes the resolution somehow. Once again any advice on settings would be a help.
OK it's a couple of days since I made this reply first and I have now found D-Vision 3 which not only joins AVIs together so they work in Quicktime (and my stand alone set-top player) every time, but also appears to be able to join more than two togethet at once! fantastic. Fan as I am of ffmpeg on this occasion I've really got to recomend the rival product.[/list]
How to join files together (mpegs, avis, etc any files!)
Here's my little tutorial, (you can use this for any video or sound file, not just the vob's like mine says...)
--REPLACE THE VOB WITH AVI IN YOUR CASE!!--
Tutorial:
Steps:
1. Open Finder
2. Click On "Applications"
3. Open "Utilities"
4. Open "Terminal"
5. In the Box that appears type "cat " and then drag {VOB1}
6. then add {VOB2}
7. put in ">"
8. and then type the title that you want the new file to have.
it will look like this:
cat movie1.vob movie2.vob >> movie.vob
YOU CAN DO THIS WITH MORE THAN 2 FILES!!!
sometimes when I join files the audio gets separated into several different tracks . I hate that. they were batched with the same preset.
why does the audio get split into separate audio tracks?G5 2ghz x2 1g ram, alchemy tv card, 200 g lacie firewire hd, formac studio dv/tv, eyetv 500; a PC and a series 2 TIVO
join several avi files
By hilario in forum EditingReplies: 2Last Post: 13th Nov 2009, 12:49 -
Join AVI files together ?
By terryfox in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2009, 22:56 -
Simplest way to join 15 avi's into 1
By macbuz in forum MacReplies: 3Last Post: 20th Jan 2009, 16:06 -
Cant join 2 AVI together!
By GangstaRap in forum EditingReplies: 2Last Post: 25th Dec 2007, 18:41 -
How do i join 2 .avi clips?
By vandaLo in forum Newbie / General discussionsReplies: 8Last Post: 13th May 2007, 20:52
