I have several xvid files I want to put on a dvd to play on my playstation 2 what do I need to do to the files to make them playable and to get the most files on a dvd? I have read that vcd is not compatible with ps2 so I was wondering my options. Thanks
...or get Action Replay Max for MP3/DivX playback.
/Mats -
ok I am trying to use cucosoft pro 5.03 to convert it to dvd. I select batch and to dvd then click add and select a file, then I click add again and select the second file and then it crashes, it tells me that Avi2MpegMain has encountered a problem etc.. the error info gives me
AppName:avi2mpg.exe
AppVer: 5.0.0.1
ModName: avi2mpg.exe
ModVer: 5.0.0.1
Offeset: 00008389
So I tried it again with only 1 file and I get a timeout error, I never had these problems with the older version I had so is there anyway to rollback and get an earlier version or does anyone know of a solution? -
ir you're trying to play raw Xvid files you'll need to mod your ps2. if you're trying to convert them to DVD so u can play them on any standalond DVD player (including a ps2) just check out the Xvid/Divx/AVi to DVD conversion guides...
The distance between genius and insanity is measured only by success... -
Probably a broken AVI, even if I wouldn't trust cucusoft - I suggest you read some guides on the subject, found left under convert. You'll find a majority uses only freeware apps.
/Mats
Make a playable file from AVI part 5 when you don't have parts 1-4?
By gumbygum in forum Software PlayingReplies: 3Last Post: 12th Aug 2011, 08:51 -
need help with HDConvertToX to make avi that is 1hr+ playable in DVD
By lett303 in forum Video ConversionReplies: 0Last Post: 6th Oct 2010, 14:30 -
Make MKV encoded with AVC Playable with Standalone DivX Player
By adalect in forum Video ConversionReplies: 2Last Post: 2nd Jun 2009, 22:42 -
non playable xvid to playable xvid on PS3
By simoupnorth in forum Media Center PC / MediaCentersReplies: 8Last Post: 6th Sep 2008, 21:12 -
How to make DVD recorder disk playable on TV with all scenes intact?
By Stabes in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2007, 14:02
