I think I have tried every codec out there, at every setting there is, what does everyone else use for the best results, whicc codec/version, and settings under flask,... for .avi. I have a copy of Red Planet that I got from friend, specs are
Video Compression-DIVXMPG4 V3
Video Sample Size-24 Bit
Data Rate-112.137 kb/sec
Frame Rate-23.976
Frame Count-153231
H/W-608 * 256
Audio-MPEG Layer3 15.963 kb/sec 44.100 khz Stereo
File Size is 699mb, and it looks like DVD
ever since I wztched this rip, I have been trying to re-create it, and cant, with the same quality output, my .AVI file size always runs over 800mb, so what do you use?
<img src="http://personal.lig.bellsouth.net/lig/c/h/chazb/Chaz.gif" border="2"> HTTP://WWW.GEOCITIES.COM/DIVXBYCHAZ
Go to doom9.org and read his section on Nandub, with GuardianKnot. Flask is very outdated and makes very poor avi's by comparison to newer methods.
Thanks, I'll give it a try.
<img src="http://personal.lig.bellsouth.net/lig/c/h/chazb/Chaz.gif" border="2"> HTTP://WWW.GEOCITIES.COM/DIVXBYCHAZ -
yes, flask mpeg has problems with some titles and very poor for DivX you can try DVDx i wrote a guide on how to use it and it should be up if Baldrick approves
I would appreciate any help, where to find your guide??
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I thought you didn't do DivX ?? -
Pardon??
i do...i only use it for videos that i hardly watch...and for Tv shows i caputured....so i wrote a guide on how i doo it
....and that VCD or Divx i was asking what i should use all the time
Settings Xvid codec in Virtualdub
By Docoptik in forum SubtitleReplies: 7Last Post: 6th Mar 2011, 14:15 -
How can I edit cedocida codec settings in windows 7?
By dssdss in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 9th Sep 2010, 02:10 -
FairUse Wizard, quantizer and codec settings
By 2dpikke in forum DVD RippingReplies: 2Last Post: 25th Feb 2010, 08:03 -
XVid codec settings question?
By 3thman in forum Video ConversionReplies: 5Last Post: 10th Oct 2009, 16:36 -
Xvid Codec settings (1.2.2)
By glenpinn in forum Video ConversionReplies: 2Last Post: 21st Jun 2009, 10:29
