Every time I try to transcode a dvd using the one click method I get an error at PHASE III. It says DVD-RB ERROR DVD-RB COULDN'T LOCATE APPRIOPRIATE FILES IN WORKING DIRECTORY! YOU MUST PREPARE & ENCODE FIRST. ABORTING. I don't know what I'm doing wrong any help would be much appreciated. Thank you.
Post your log. Sounds like you don't have the output path set correctly. If you use the installer, it will set all of this for you.
Transcoding...
[22:41:20] Phase I, PREPARATION started.
- "Steal Space from Extras" mode is enabled.
- VTS_02: 3,831,946 sectors.
-- Scanning and writing .D2V file
-- Processed 244,860 frames.
-- Building .AVS and .ECL files
- Reduction Level for DVD-5: 51.7%
- Overall Bitrate : 2,828Kbs
- Space for Video : 3,525,266KB
- Movie improvement from extra reduction = .0%
- HIGH/LOW/AVERAGE Cell Bitrates: 4,363/393/2,828 Kbs
[22:47:21] Phase I, PREPARATION completed in 6 minutes.
[22:47:21] Phase II ENCODING started
- Creating M2V for VTS_02 segment 0
- Creating M2V for VTS_02 segment 1
- Creating M2V for VTS_02 segment 2
- Creating M2V for VTS_02 segment 3
- Creating M2V for VTS_02 segment 4
- Creating M2V for VTS_02 segment 5
- Creating M2V for VTS_02 segment 6
- Creating M2V for VTS_02 segment 7
- Creating M2V for VTS_02 segment 8
- Creating M2V for VTS_02 segment 9
- Creating M2V for VTS_02 segment 10
- Creating M2V for VTS_02 segment 11
- Creating M2V for VTS_02 segment 12
- Creating M2V for VTS_02 segment 13
- Creating M2V for VTS_02 segment 14
- Creating M2V for VTS_02 segment 15
- Creating M2V for VTS_02 segment 16
- Creating M2V for VTS_02 segment 17
- Creating M2V for VTS_02 segment 18
- Creating M2V for VTS_02 segment 19
- Creating M2V for VTS_02 segment 20
- Creating M2V for VTS_02 segment 21
- Creating M2V for VTS_02 segment 22
- Creating M2V for VTS_02 segment 23
- Creating M2V for VTS_02 segment 24
- Creating M2V for VTS_02 segment 25
- Creating M2V for VTS_02 segment 26
- Creating M2V for VTS_02 segment 27
- Creating M2V for VTS_02 segment 28
- Creating M2V for VTS_02 segment 29
- Creating M2V for VTS_02 segment 30
- Creating M2V for VTS_02 segment 31
- Creating M2V for VTS_02 segment 32
- Creating M2V for VTS_02 segment 33
- Creating M2V for VTS_02 segment 34
- Creating M2V for VTS_02 segment 35
- Creating M2V for VTS_02 segment 36
- Creating M2V for VTS_02 segment 37
- Creating M2V for VTS_02 segment 38
- Creating M2V for VTS_02 segment 39
- Creating M2V for VTS_02 segment 40
- Creating M2V for VTS_02 segment 41
- Creating M2V for VTS_02 segment 42
- Creating M2V for VTS_02 segment 43
- Creating M2V for VTS_02 segment 44
- Creating M2V for VTS_02 segment 45
- Creating M2V for VTS_02 segment 46
- Creating M2V for VTS_02 segment 47
- Creating M2V for VTS_02 segment 48
- Creating M2V for VTS_02 segment 49
- Creating M2V for VTS_02 segment 50
- Creating M2V for VTS_02 segment 51
- Creating M2V for VTS_02 segment 52
- Creating M2V for VTS_02 segment 53
- Creating M2V for VTS_02 segment 54
- Creating M2V for VTS_02 segment 55
- Creating M2V for VTS_02 segment 56
- Creating M2V for VTS_02 segment 57
- Creating M2V for VTS_02 segment 58
- Creating M2V for VTS_02 segment 59
- Creating M2V for VTS_02 segment 60
- Creating M2V for VTS_02 segment 61
- Creating M2V for VTS_02 segment 62
- Creating M2V for VTS_02 segment 63
- Creating M2V for VTS_02 segment 64
- Creating M2V for VTS_02 segment 65
- Creating M2V for VTS_02 segment 66
- Creating M2V for VTS_02 segment 67
- Creating M2V for VTS_02 segment 68
- Creating M2V for VTS_02 segment 69
- Creating M2V for VTS_02 segment 70
- Creating M2V for VTS_02 segment 71
- Creating M2V for VTS_02 segment 72
- Creating M2V for VTS_02 segment 73
- Creating M2V for VTS_02 segment 74
- Creating M2V for VTS_02 segment 75
- Creating M2V for VTS_02 segment 76
- Creating M2V for VTS_02 segment 77
- Creating M2V for VTS_02 segment 78
- Creating M2V for VTS_02 segment 79
- Creating M2V for VTS_02 segment 80
- Creating M2V for VTS_02 segment 81
- Creating M2V for VTS_02 segment 82
- Creating M2V for VTS_02 segment 83
- Creating M2V for VTS_02 segment 84
- Creating M2V for VTS_02 segment 85
- Creating M2V for VTS_02 segment 86
- Creating M2V for VTS_02 segment 87
- Creating M2V for VTS_02 segment 88
[22:47:27] Phase II ENCODING completed in 0 minutes.
[22:47:27] Phase III, REBUILD started.
- Copying IFO, BUP, and unaltered files...
Rebuild aborted.
bd-rebuilder problem
By mathbes in forum Blu-ray RippingReplies: 3Last Post: 12th Feb 2012, 04:15 -
BD Rebuilder new version problem
By fazza8 in forum Blu-ray RippingReplies: 5Last Post: 20th Aug 2009, 06:36 -
BD Rebuilder 22.01 Problem
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 2nd Jun 2009, 13:36 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 13:25 -
problem with dvd rebuilder!
By jonkiller in forum DVD RippingReplies: 1Last Post: 2nd Aug 2007, 08:58
