I have have seen sometimes on dvd's where once the dvd starts it says vcd in the top righthand corner
so how do you put a vcd thats over 700mgs on a dvd disk?
anyone know?
TMPGEnc DVD Author is a good program to do this.
Here: http://www.digitalfaq.com/convert/vcdtodvd/vcdtodvd.htmCole -
the two main things you need to do is 1) make sure its 29.97 fps (or the
PAL equiv.), and 2) strip off the audio track and convert it from 44.1 hz to 48000 hz.
I use TMPEGENC to demux to video and audio files, then BeSweet to
transcode the audio up to 48000hz.
then i load the audio and video file into Ulead DVD Workshop 2,
whip up a menu, drop some chapter points, and 'burn' it to a
TS_Video folder for burning to disk with NERO.
it doesnt do any internal converting of the video file as long
as its 29.97 fps and 48khz audio) and it plays fine on all the set-top players i've ever tried it on - although as rule of
thumb i'd say it'll only work on DVD players that play VCD and SVCD files.
I do it all the time with tv episodes i miss and end up downloading
later.
you can do the same with SVCD by using DVDPatcher to reset the
header from 480X480 to 352X480 (or the pal versions) for authoring,
then rerun it on the produced VOB files and switch it back to 480X480
before burning.
works fine, and there is no quality loss in image from reconverting.
- Will.
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 16th Jun 2010, 23:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 10:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
