I used the smart ripper and it worked brilliant, I've got the required VOB files to start working and I used the DVD2AVI prog to frame serving it, it worked fine also but when I checked to see if I had the same files I only had the movie.d2v file but not the sound file, instead I had a '.MPA T01 Delay - 80ms' file. I ran the file and it seem to a sound file but I can't input it on the audio source in TMPGEnc programme(cus its a .MPA file). When I try to inport it, it says it doesn't support it. The video one works in that prog and encodes but theres no sound.
The original DVD has .VOC and .IFO files and another one which I can't remember.
can you help!
